plumster Posted May 3, 2023 Share Posted May 3, 2023 (edited) Has anyone seen any of the shields that sit behind the front brake discs for sale anywhere? Just spotted these, anyone tried them? https://www.ebay.co.uk/itm/353255919028?hash=item523fb18db4:g:c6kAAOSwC4JfnDXu&amdata=enc%3AAQAIAAAA4GvvHAow4Y6lnpBsMpgsmnhZCz9R4bCyCQiyENzLgepl2N2piF%2BmJDZpFbhsHrQG3iz8WDJyAeQW2%2Bbc0ZUcr%2F2TFVJShn9M4Z4FWF0zAZRHRsQ%2FlEU7bmzV72eHdT6If%2F6umQ0vtAT8MBDj2K%2BNgw83SAFiO4RNoapZzSlDXMtB0BPYba5ZSso1%2BztZmW%2F33atkR1PeoquUDZrTMclredC1UUKvwcqTa8sZoAtsyDa9qF%2B6xwsqdDu1600bKMblYogrYtr27d9tAyib%2BTvmiJMRnAKo40ZyFcPkO3RkMx3I|tkp%3ABk9SR_LtwKn8YQ#vi-desc-maincntr Cheers. Sam. Edited May 3, 2023 by plumster Link to comment Share on other sites More sharing options...
Moonmonkey Posted May 3, 2023 Share Posted May 3, 2023 I bought something similar off another ebay seller (£10 more expensive actually). They worked fine. I was using them for a 4 pot big disc upgrade so was cutting away a chunk of them and didn't want to cut the originals When I looked at them the hole is off centre but the bolts holes and the hub are central and aligned. The hole is oversized so while it is off centre it doesn't have an impact 1 Link to comment Share on other sites More sharing options...
plumster Posted May 4, 2023 Author Share Posted May 4, 2023 Nah then, I have ordered a set of shields from ebay, but I need a seal repair kit for the AC Delco BMF type calipers. I'm sure I saw some advertised, but I simply cannot find them. Anyone help??? Link to comment Share on other sites More sharing options...
®evo03 Posted May 4, 2023 Share Posted May 4, 2023 Biggred, site or eBay shop 👍 Link to comment Share on other sites More sharing options...
plumster Posted May 4, 2023 Author Share Posted May 4, 2023 Found them at Autodoc, or should I say... re-found them.. 1 Link to comment Share on other sites More sharing options...
plumster Posted May 15, 2023 Author Share Posted May 15, 2023 Look pretty good after powder coating.. 1 Link to comment Share on other sites More sharing options...
®evo03 Posted May 17, 2023 Share Posted May 17, 2023 Biggred can help with caliper seals, think there is also discount OMOC, check with them. 1 Link to comment Share on other sites More sharing options...
Irmscher Man Posted May 18, 2023 Share Posted May 18, 2023 On 17/05/2023 at 09:56, ®evo03 said: Biggred can help with caliper seals, think there is also discount OMOC, check with them. They should give you 10% discount if you tell them you are a club member and quote membership number. Link to comment Share on other sites More sharing options...
plumster Posted May 26, 2023 Author Share Posted May 26, 2023 On 18/05/2023 at 18:06, Irmscher Man said: They should give you 10% discount if you tell them you are a club member and quote membership number. I got a couple of Caliper service kits & finished the job today, just need to bleed one where I changed the hose & we're good to go. Cheers guys for your advice, BigRed seem like the place if your calipers are goosed, mine are fine with a good service. Link to comment Share on other sites More sharing options...
