Aftermarket cam
Nivlek2525
10 hours ago, H-400 said:
Above the tool used by Opel shops to check the chain/ tensioner/guides. Screw the tool in the timing house and screw the piston until the chain has got his tension. Measure the distance X . Measure the same distance on your chain tensioner and it must be at least 2mm longer than X. If less the chain is stretched.
In the same text they mention you can fix that problem by cutting of the contactsurface on a lathe, but I'm not a fan of this. I would fit a new chain with new guides. The tool looks to be made of an old used tensioner but I used once a long bolt with a nut & washer, works fine
Hi Herman.
That's really useful thanks. I did this although not very accurately at the weekend and found it to be too short. I will try again to try to get a more accurate measure just for interest but I have a new chain on the way so will be fitting it afterwards. I think I'll take a measure once new chain is installed as a datum to check o. Wear in the future.
Regards
K.
7 hours ago, cam.in.head said:
you CAN change a cam with the head on but it means removing one ormore headbolts but i dint think there will be anything wrong with your cam . it sounds like you have definately got a  stretched chain ( or tensioner arm worn out !) so a new chain should sort it. dropping the sump is the only real way to get the timing casing back on with the head in place but you will need to remove the locating dowels to allow it to go in and up ,tightening the two 6mm allen bolts in the head to pull it up in place whilst / along with the front ones to align it and get the dowels back in
Thanks for this. I think I have another head gasket somewhere but I don't have spare inlet/exhaust gaskets or down pipe gasket. I'll try to leave head in place but if I struggle I'll just take it off again. It makes confirming tdc a little easier anyway.
TDC flywheel marker is as accurate as your likely to need. Front pulley is not one I would be going for. Idont forget to set distributor rotor ram to the marking too (pic is Bosch disi, but not on CIH, but marking is same
On 29/01/2024 at 09:25, H-400 said:
Just a quick update and comparison photos for interest.
New chain arrived from Andy (thanks Andy!)
Hopefully I'll get it all back together on Friday (day off) and hopefully everything will be a bit quieter......
Thanks all.
K.
Edited by Nivlek2525
Error
  • Thanks 1
Thanks all.
K.
Visible difference there 👍
So...
The GOOD news.
New chain on. All timed up perfectly.  Runs lovely and the industrial sewing machine noise is totally gone.
https://photos.app.goo.gl/oZGwCLPqDnPWxAkC7
The video doesn't do it justice as it still sounds very metallic but it's not much different to my mk1 mx5 so I'll take that. Revs lovely and freely.
Exhaust note is just on the acceptable side of boy racers.
https://photos.app.goo.gl/C9QnFwJtEicPwKCr7
But I quite like it.
So happy days?
Not quite.
It was bone dry, but now I have an unacceptable oil leak from between the chain cover and the head. I should have pulled the cylinder head this morning and saved a days messing about.
https://photos.app.goo.gl/L91ooRxcp7CW88NZ7
So I need to get a few gaskets together and pull it all a part again. 1 step forward...
Typos
1 hour ago, Nivlek2525 said:
So...
The GOOD news.
So happy days?
Not quite.
That's great news, glad the chain sorted it.
The old CIH do sound a bit industrial
https://www.theopelproject.com/engine-all-setup/
Have you checked its not the rocker cover gasket leaking? as i have an ally rocker cover and had lots of problems with the cork gasket on mine the second time around, so swapped to the rubber one and had no issues at all after that.
Andy
Andy
Hi Andy,
Yes, chain sorted the horrible sound out so I'm chuff overall but I need to sort that leak.
No, it's defo coming from between the head and chain cover. I nipped up the two long bolts that go through the head and that helped but its still leaking.
Now the cam is all timed up and the hydraulic tappets set its not a big job.
If I can find my spare head gasket I might get it done tomorrow.
K.
2 hours ago, Nivlek2525 said:
Hi Andy,
K.
Hi Kelvin
At lest you have solved the main issues, the oil leak should be reasonably easy 🙂
Andy
2 hours ago, Jessopia74 said:
Oil feed to head? Did you remember to put the rubber seal back in place?
Just now, Nivlek2525 said:
No, I remembered that.
I just managed to push the gasket inside the chain cover because I was being stupid.
I think it's fixed now.....hopefully.
wow .whats the chances of that happenning ?   however at least you have found it and you can now replace the gasket and fit it like it was realy intended to be done . and great that its all quiet now.  the chain was quite badly stretched. !
https://photos.app.goo.gl/QtDJc7WruZhGjPd6A
Fixed.  Idle a little high but otherwise OK.
Up to temperature.  No leaks so far. Sounds much better.
Engine bay a disaster area and so is the garage but that's next weekends job.
Thanks all.
Sounding good.
My garage is a bit like that with bit of Fiat all over the place and in the way of the Opel 🙂
  • Haha 1
