Insky Posted April 14 Share Posted April 14 I bought a new voltage stabilizer which i was going to attempt to fit today, looking at a previous post it said it's behind the dash and you just pull the old one out. Well i have been on my back and up behind the dash and i can't even see it, mind you it would help if i knew where to look. Is it to the right or left of the speedo or below, if someone can point me in the right direction it would be most appreciated. Quote Link to comment Share on other sites More sharing options...
Mike. Posted April 14 Share Posted April 14 If my memory serves me right, remove the binnacle cover and get access to the top left rear of the instrument cluster, it’s a gold coloured rectangle just pushed in, it’s kind of awkward to get at, just take your time. Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted April 14 Share Posted April 14 hi you can get to it from behind by removing the dash section below the steering column and also the right hand black plastic heater duct . its very fiddly but you can see it if you look up . its roughly behind the oil pressure guage area . its a feel to fit job and all you need to be sure of is that the pins locate properly . 1 Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted April 14 Share Posted April 14 OTHERWISE if its too fiddly then take the top dash cowl off ( removing fan and hrw switches and screws first) and then undo the instrument pod and lift it out . you should be able to reach in and get it ( or reach into speedo cable and release furst if not enough room ?) but definately worth trying from below first ! Quote Link to comment Share on other sites More sharing options...
Insky Posted April 14 Author Share Posted April 14 Many thanks for the info it gives me something to work with, will give it a go tomorrow and i'll try it from below first and see how it goes. Quote Link to comment Share on other sites More sharing options...
Mickfrad Posted April 14 Share Posted April 14 Photo stolen from the internet but hopefully help with general location. 2 Quote Link to comment Share on other sites More sharing options...
Insky Posted April 14 Author Share Posted April 14 Cheers Mick, shows exactly where it is and where i have to look, when i looked today just could not spot it, hopefully i will get new one fitted tomorrow. Quote Link to comment Share on other sites More sharing options...
Insky Posted April 15 Author Share Posted April 15 Good news, i managed to fit the stabilizer today, took off bottom section of dash and heater duct to gain access and you have enough room to get one hand in, only problem was there were three wires sitting in front of it but after some gentle persuasion got them moved out of the way. Old unit a bit tight to come but managed eventually, fitting the new one was fiddly because you can't see what you're doing and you have to go by touch but got there in the end. Well worth the aggro because i now have a temperature guage that is working normally instead of climbing up to the red. 3 Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted April 16 Share Posted April 16 We are at a point now where I’d be surprised if any original ones are working correctly. I had 5 or 6 in a box and they were all broken. The better one online has been no problem at all. I always take the binicle off to replace them now. 1 Quote Link to comment Share on other sites More sharing options...
Insky Posted April 16 Author Share Posted April 16 I got my replacement one on ebay, in fact i bought two as they are no money at all and you never know what's round the corner. Nothing wrong with it and is working perfectly. Just for curiosity is there anyone else who supply them because i did look around before finding one. Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted April 17 Share Posted April 17 13 hours ago, Insky said: I got my replacement one on ebay, in fact i bought two as they are no money at all and you never know what's round the corner. Nothing wrong with it and is working perfectly. Just for curiosity is there anyone else who supply them because i did look around before finding one. I’ve not found anyone else other that Edelschmiede but to buy one you’ll pay more for the postage. Quote Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted April 17 Share Posted April 17 8 hours ago, Sutty2006 said: I’ve not found anyone else other that Edelschmiede but to buy one you’ll pay more for the postage. I tried this one. I wasn’t disappointed 😎 https://www.ebay.co.uk/itm/285235278029?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=SpBAFWooRDC&sssrc=4429486&ssuid=GJ2Qb-ssS3-&var=&widget_ver=artemis&media=COPY 1 Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted April 17 Share Posted April 17 49 minutes ago, Jonathan Pounsett said: I tried this one. I wasn’t disappointed 😎 https://www.ebay.co.uk/itm/285235278029?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=SpBAFWooRDC&sssrc=4429486&ssuid=GJ2Qb-ssS3-&var=&widget_ver=artemis&media=COPY Yeah, no one else other than that UK bloke and Edelschmiede. Mind you, Edelschmiede probably order off him first 🤣 1 Quote Link to comment Share on other sites More sharing options...
