SCBESH1 Posted July 23 Share Posted July 23 Hi all , anyone know of any common problems with the rev counter not working on a 1988 exclusive.i have checked the supply from the coil and all is good at the plug at the back of the clock. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted July 23 Share Posted July 23 Green wire from coil pack is tach output, it’s not a live feed as such. Does needle flick on startup or anything? Quote Link to comment Share on other sites More sharing options...
SCBESH1 Posted July 23 Author Share Posted July 23 No it doesn’t move at all. Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted July 23 Share Posted July 23 Do you have a multimeter? You can do a basic check at the back of your gauges with a multimeter. But if it’s GTE and runs fine, then the tacho signal is present as it also feeds the fuel pump relay for RUN signal. Quote Link to comment Share on other sites More sharing options...
hoobby Posted July 24 Share Posted July 24 could be worth a look at if you have no luck. 1 Quote Link to comment Share on other sites More sharing options...
SCBESH1 Posted July 24 Author Share Posted July 24 Thanks , I give that a go. Many thanks Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted July 24 Share Posted July 24 for wiring check and power you can remove the dash top and front binnacle to access the tachometer. it can be unscrewed and pulled out of the dash. you are left with 3 terminal sockets one will be live with ign on ,one will be negative permanently and the other should have continuity to the green wire at the coil ( test unplugged to avoid any false readings) if all is well and engine runs normally anyway then it sounds like a tachometer issue . rare thou ! Quote Link to comment Share on other sites More sharing options...
®evo03 Posted July 24 Share Posted July 24 I had a intermittent rev counter a few years ago, it would drop, and then reset, not very often, I don't know if it's coincidence, but I rebuilt my alternator, and cleaned all connectors, rev counter is sorted, 👍 Quote Link to comment Share on other sites More sharing options...
SCBESH1 Posted July 24 Author Share Posted July 24 Thanks everyone, I will do some more investigating and see how it goes. 👍 2 Quote Link to comment Share on other sites More sharing options...
