Tj Motorsport - Alloy Hubs
TJM
Hello to all,
I am getting another batch of alloy hubs made for the Manta/Ascona/Chevette/Kadett in the following specs.
10 x Standard direct replacement 4 stud. (£80 each).
6 x Special replacement 5x120PCD with larger 72.6mm spigot to mount BMW Wheels. (£80 each). These hubs are 20mm larger overall on the hub face to accommodate the special PCD. Studs would also need be supplied with these at extra £9.50.
I already have the Group 4 versions in stock. (£90 each).
P&P is extra.
Regards
Tim
I already have a set, they are fantastic quailty and the easiest way to convert to Manta 5 stud....
May I just ask how you changed the rear to 5x120? different axle? or is it possible to fabricate different stub axles?
Sorry for the off-topic.
Cheers,
Mike
Simon
Would you want any other change, or is it a standard hub with standard spigot diameter and different pcd, or do you want a different spigot diameter?
Regards
Tim
Just a stock hub with the different PCD, i'll like studs too, are they 12x1.5?.
Cheers,
Mike
Commodore rear shafts, just have to take a few thou off the standard outer bearing and they fit straight in, used to run them on the rallycar like that with a standard type Manta B axle and never had a problem with them :thumbup
Hello to all,
Hubs will be available by end of this month so if I can get payment in, that would be great.
£80 each for hubs = £160.00
£1.50 per stud (including extra machining) £12.00
P&P £10.00 (24-72 hour) (Can get it quicker if required at extra charge).
Total £182.00.
Cheque is preferable but will accept Paypal if required.
Regards
Tim
FAO TJM
Remember the hub attachment for knock-on / knock-off wheels on Triumphs, Midgets and Jags?
Can't be bothered to draw it but basic idea would be to have something like the above but thicker to allow proper nuts on short studs so about an inch thick and no central hole but with a spigott on the outside to fit BMW wheels and back bored to allow the Manta half shaft spigott to centrally locate.
Then a BMW rear disk drops over the BMW / Manta 120 PCD. All those moans people used to have about the Escort rear disks dissappear as there is positive location onto the half shaft and for the disks and wheels.
What do you think?
I'm almost certainly up for a pair. Maybe stainless?
  • 3 weeks later...
Hello to all,
Will be collecting hubs on Friday so please can I get payment in.
Also mantadoc how many people would be interested in these. To make it worthwhile my machinist normally requests a minimum of 7 pairs but 10 is better.
Regards
Tim
FAO TJM
What do you think?
I'd be up for a pair of these,poss 2 depending on the cost
Andy
  • 4 months later...
Hi Tim, just wondered if your still doing the alloy hubs, and if so can i have them totally custom , not sure of my exact requirement yet but looking for a 5x112 p.cd. Centre spigot im unsure of and also the offset. Im looking to install some mercedes alloys onto my manta , waiting to pick them up yet so i can have a measure then.
Would be interested if you could confirm wether you still are having them made? cheers Lee
  • 3 years later...
P&P is extra.
Regards
Tim
Hi Tim
Are these still available? Cheers Kris.
PS could you please mail me? kriswijnants at hotmail.com
Hello
I can get these made but only as part of a batch.
Recently had a batch made but all sold. If I could get a few more orders I would do another batch.
Regards
Tim
