Thomas77GR Posted October 24, 2012 Share Posted October 24, 2012 Hi all sorry for the naive question, what plugs do people here have on their mantas (ngk, bosch etc?), reasons for choice? just curious as I want to buy me some new for my A series. can you recommend me something? it's a standard A series fitted with a 2.0 block and webber card. thanks in advance Thomas Quote Link to comment Share on other sites More sharing options...
Scribe of Lincoln Posted October 24, 2012 Share Posted October 24, 2012 Always found NGK to be the best (I'm also 2.0 with Weber carb). Try abpartstraders on E bay - I recently paid £7.61 for a set of 4 x BPR 6H I've found Champion plugs to be not so good. Recently bought a new set of leads from Accuspark (see E-bay) which were good value and seem fine. Quote Link to comment Share on other sites More sharing options...
1900SR Posted October 24, 2012 Share Posted October 24, 2012 I always try and use NGK as well. Quote Link to comment Share on other sites More sharing options...
rutts Posted October 24, 2012 Share Posted October 24, 2012 i use denso iridium plugs usually very good but a tad expensive try ebay, best plug leads by far are magnecore great guy to deal with and top quality for the price. :D Quote Link to comment Share on other sites More sharing options...
Shug Posted October 24, 2012 Share Posted October 24, 2012 I have ngk and magnecor on mine. Tho my manta isn't exactly an advert of reliability, the plugs and leads are good! Quote Link to comment Share on other sites More sharing options...
madmantamik Posted November 10, 2012 Share Posted November 10, 2012 i would steer well clear of the champion plugs, i have had cars refuse to start from cold with these fitted,its got to be NGK for me . as for plug leads this depends on wether you are using electronic ignition. it is worth bearing in mind silicone leads need only be used where heat is a factor , which it is not on the cih engine. Quote Link to comment Share on other sites More sharing options...
monzta Posted November 11, 2012 Share Posted November 11, 2012 I agree on NGK is the best choice. Also using good leads are very important as there is alot of resistance in the ignition parts itself on the old cars. The thicker and better leads the better imo. Magnecor has what you need in that department. Otherwise you can actually buy a complete set for DIY wich is something i have considere many times. You can make leads like 14mm thick and with a absolute minimum of resistance. Quote Link to comment Share on other sites More sharing options...
Robert1234 Posted December 15, 2012 Share Posted December 15, 2012 A pack of NGKs were £4 from halfords, cant remember what they were exactly. They were for a B GTE. Quote Link to comment Share on other sites More sharing options...
Shuviteer Posted December 16, 2012 Share Posted December 16, 2012 The thicker and better leads the better imo. Magnecor has what you need in that department. Otherwise you can actually buy a complete set for DIY wich is something i have considere many times. You can make leads like 14mm thick and with a absolute minimum of resistance. Just make sure if you get thicker leads that they will fit into the ends of the dizzy cap ! I got caught out once by not giving it a second thought !!! Quote Link to comment Share on other sites More sharing options...
