Manta "magic"
Magic
Did you have the bushes custom made?
I just had a look at the Deuter web site and they don't list the Manta.
Do you still have the Deuter part numbers ?
I need a set for my Manta A.
cheers Chris.
It's true, Manta A is not in the list. Such sets of Poland sells very little-perform them on an individual order. Best to send a complete suspension, regenerate and send them to you. I also sent the old rubber on the model.
progress
repair upper seat coil spring- rear:
custom template paper:
steel # 1 mm:
again custom template paper:
steel # 2 mm:
final welding:
recovered mounting element ( Please correct me if I write wrong):
next step-
My friend ( Globi from Mantaclub.pl) replace bearings and adjusted gear-
(photo from Globi):
tools:
dismantling:
reassembly :
adjusted:
assembly crownwheele:
pleass correct my text if not grammatical
right chassis repair:
-setting the body
before:
repair interior:
anticorrosive paint ( epoxy ):
outer plate ( #1 mm)
clean, clean, clean (!)
The end:
rear wheel arch inner ( well translated? please correct ):
Edited by Magic
