eurocamper1 Posted March 12, 2013 Share Posted March 12, 2013 My heater fan is not working dosn't turn i got voltage in the black wire going into the motor but nothing in the yellow and grey or at the switch im guessing i need a new blower motor or is there anything else to check Thanks Henrik Quote Link to comment Share on other sites More sharing options...
spiney_norman Posted March 12, 2013 Share Posted March 12, 2013 They do quite often seize up when they haven't been used for a while. Have you tried taking the fan out and turning it by hand? Quote Link to comment Share on other sites More sharing options...
mantadoc Posted March 12, 2013 Share Posted March 12, 2013 The grey and yellow go through the resistor. I can't remember if they are switched earth or switched live now but I can tell you the following: 1) The switch is often the issue they melt inside. Easily tested with switch removed and two male spade terminals on 2" on wire. 2) The pins in the connector on the heater box corrode and over heat. Visual inspection and / or voltmeter (in fact ohm meter) test. 3) The bearings collapse and the fan floats and jams (end float). Can sometimes be freed by hand but usually happens again. 4) The resitors get hot if they are drawing too much current and the glow can be seen through the vents in the dark 5) The fans die, been years since I ran out of good fans so I came up with an OEM looking fix that is better than the original http://www.atcy66.dsl.pipex.com/misc/fan/'>http://www.atcy66.dsl.pipex.com/misc/fan/ Quote Link to comment Share on other sites More sharing options...
mantasrme Posted March 13, 2013 Share Posted March 13, 2013 The grey and yellow wires go through the switch to earth, so check that end of the wiring. Or just connect an earth to one of the wires by the plug to test. Its possible its a bad connection in the plug, try wiggling the plug with the fan switched on and see if you get anything. If you do the pins in plug can be opened slightly in the loom of closed a little in the fan plug to improve the connection. But most likely is if you take the fan out and try turning it by hand It might not turn at all, they do seize up if the car has been sat in a damp atmosphere for a long time. Even if it turns it should do so freely and not be tight or notchy They can be un-seized and free'd off sometimes with oil and manually rotating them but often are not very good afterwards. If the fan turns try connecting wire from a battery to the back of the motor (power to black and an earth to either yellow or grey) to check the motor. If it works you have a wiring/plug issue if it doesn't its a fan motor/resisitor issue. Either way the best soluton is to replace the motor with a more modern one like Mantadoc says. I use the later VW polo 6n (1994-1999 models) fans and resistors as they are easy to source and very reliable. The resisitors give 4 speeds in the polo but i connect them to speeds 2 and 4 for the manta conversions. Must remember to take some pictures next time i make a batch and do a how to guide. Quote Link to comment Share on other sites More sharing options...
plumster Posted March 13, 2013 Share Posted March 13, 2013 Mmmm, mine screams like a bitch.. if anyone has a good replacement I would be interested, they are easy to change. Quote Link to comment Share on other sites More sharing options...
mantasrme Posted March 13, 2013 Share Posted March 13, 2013 Mmmm, mine screams like a bitch.. if anyone has a good replacement I would be interested, they are easy to change. That'll be worn bushes on the shaft, a bit of wd40 or GT85 quietens it for a while but it'll come back again. PM sent re replacement Quote Link to comment Share on other sites More sharing options...
kenny dock Posted March 23, 2013 Share Posted March 23, 2013 i had this problem as well, if the fan has seized it will keep popping fuses and your reverse lights will not work either. mine just needed taking out cleaned and freed up. works a treat now. Quote Link to comment Share on other sites More sharing options...
