rutthenut Posted April 20, 2014 Share Posted April 20, 2014 Wow, axle ratio of 5.1:1, that's low-geared. Guess the tyre diameter is a bit bigger on the 400 wheels, but speed what will it be geared for? Assume max for rallying would be 120 or so? Quote Link to comment Share on other sites More sharing options...
Autocrosser Posted April 20, 2014 Author Share Posted April 20, 2014 Yeah should be somewhere thereabouts you don't need much more than 110-120mph for rallying. The xe that's going in should rev to 8-8.5k. My mates grp4 escort is the same set up but with 13" wheels and it cracks 100 ok. Your v8 will be lower revving so you'd probably not get away with a 5.1 I'm guessing probably a 4.2 would suit a v8 better Quote Link to comment Share on other sites More sharing options...
rutthenut Posted April 21, 2014 Share Posted April 21, 2014 (edited) Your v8 will be lower revving so you'd probably not get away with a 5.1 I'm guessing probably a 4.2 would suit a v8 better When you say lower revving, that old Rover lump only gets to 5500 rpm. Ok, it has reasonable torque but that does make for quite a limited rev range, especially in lower gears. As I'm using a Manta axle, either standard or GT/E ratios will do fine, even if not ideal. Plenty more important things for me to address first! Edited April 21, 2014 by rutthenut 1 Quote Link to comment Share on other sites More sharing options...
spike Posted April 23, 2014 Share Posted April 23, 2014 You made the right choice Craig.Not cheap but you can pick up the phone and get anything for it,try doing that with a 400 axle. You wont be waiting for the halfshaft to break now. Spike 1 Quote Link to comment Share on other sites More sharing options...
Autocrosser Posted May 2, 2014 Author Share Posted May 2, 2014 Back of the car looks very different now Quote Link to comment Share on other sites More sharing options...
rutthenut Posted May 2, 2014 Share Posted May 2, 2014 That is certainly different to the small tunnel mods earlier in this post! Four-link boxes definitely need some space, as well as the prop tunnel. 1 Quote Link to comment Share on other sites More sharing options...
Autocrosser Posted May 2, 2014 Author Share Posted May 2, 2014 Fair bit of work involved but well worth it. Got the modified bottom arm mountings to weld up and fit skids to them. Hopefully have it all welded up this weekend 1 Quote Link to comment Share on other sites More sharing options...
Autocrosser Posted May 3, 2014 Author Share Posted May 3, 2014 Got the bottom arm mounts welded up tonight. Bottom arms to strengthen and the panhard rod to shorten next. This is my take on a 400ish rear end 1 Quote Link to comment Share on other sites More sharing options...
Autocrosser Posted May 4, 2014 Author Share Posted May 4, 2014 Got the 400 arms boxed and strengthened this afternoon 2 Quote Link to comment Share on other sites More sharing options...
Autocrosser Posted May 17, 2014 Author Share Posted May 17, 2014 Repaired these tonight God knows why they rot there! And got it up onto the spit Eventually got a lend of it for a couple of weeks (a year too late) 1 Quote Link to comment Share on other sites More sharing options...
Autocrosser Posted May 18, 2014 Author Share Posted May 18, 2014 Nothing like doing things backwards 1 Quote Link to comment Share on other sites More sharing options...
Autocrosser Posted May 21, 2014 Author Share Posted May 21, 2014 Getting through the last few bits and pieces of metalwork. Before:- And after:- And started priming up the inside Quote Link to comment Share on other sites More sharing options...
rutthenut Posted May 22, 2014 Share Posted May 22, 2014 Making me envious now. Wishing I had the skill (and time, money, facilities in suitable mix) to do that great work you've been doing on this car. Looking forward to continuing to see it come together. 1 Quote Link to comment Share on other sites More sharing options...
Autocrosser Posted May 22, 2014 Author Share Posted May 22, 2014 Making me envious now. Wishing I had the skill (and time, money, facilities in suitable mix) to do that great work you've been doing on this car. Looking forward to continuing to see it come together. Thanks John, anyone can do this kind of thing it's all a question of patience......lots and lots of patience! I'm a self employed joiner so it's not even my trade! 1 Quote Link to comment Share on other sites More sharing options...
Autocrosser Posted May 24, 2014 Author Share Posted May 24, 2014 Got the underneath and inside all primed up and the firewall reinstated. Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted May 24, 2014 Share Posted May 24, 2014 looking like it means business! 1 Quote Link to comment Share on other sites More sharing options...
Autocrosser Posted May 25, 2014 Author Share Posted May 25, 2014 Today I got the one bit of the car I wasn't happy with sorted. The replacement A pillar once cleaned up was still rusting from the inside out......not any more! It's the last bit the welding is now finished 1 Quote Link to comment Share on other sites More sharing options...
Autocrosser Posted May 31, 2014 Author Share Posted May 31, 2014 (edited) In-between Jim Clark rally duties I've managed to get some painting done Edited May 31, 2014 by Autocrosser 3 Quote Link to comment Share on other sites More sharing options...
rutthenut Posted May 31, 2014 Share Posted May 31, 2014 So sad / sorry to hear the tragic news from that event. But good progress on the car, it's looking magic Quote Link to comment Share on other sites More sharing options...
Autocrosser Posted May 31, 2014 Author Share Posted May 31, 2014 It's a sad day indeed John. Motorsport's a spectacle to be enjoyed by competitors and fans alike and days like this thankfully are few and far between. My heart goes out to the those involved and there family's. Quote Link to comment Share on other sites More sharing options...
Autocrosser Posted June 2, 2014 Author Share Posted June 2, 2014 Last few nights work 2 Quote Link to comment Share on other sites More sharing options...
Autocrosser Posted June 6, 2014 Author Share Posted June 6, 2014 Cracking on with the front end tonight Anyone any advice on where the cheapest place to get poly bushes for the front end is?? 1 Quote Link to comment Share on other sites More sharing options...
spiney_norman Posted June 9, 2014 Share Posted June 9, 2014 Good work there! Retro Power do complete front end kits, they're as cheap as anyone I know of 1 Quote Link to comment Share on other sites More sharing options...
Autocrosser Posted June 9, 2014 Author Share Posted June 9, 2014 Front end starting to look a bit more like the thing 1 Quote Link to comment Share on other sites More sharing options...
Autocrosser Posted June 10, 2014 Author Share Posted June 10, 2014 Bais pedal box and steering column fitted tonight Quote Link to comment Share on other sites More sharing options...
