Shortened Dampers
Robert1234
  • 1 month later...
I believe the mk1 cav is just a manta, on the mini dampers where the bottom end of the damper bolts to the top of the wishbone it is narrower than a manta damper.
Also I believe I chopped about 2 inches off the cone.
At first I tried to push the sleeve out of the manta dampers but the sleeves seemed to be stuck to the bush somehow, so that idea went out the window, it destroyed the standard bush and also when I tried to push the sleeve out of the mini dampers it seemed like it would do the same.
You may have more luck, I might try it another day.
The averagely bodge method would be take a sleeve from an original damper and then cut it to use as spacers for each side of the new dampers.
I had to go to work so I didn't have the time for this so I just spaced it out with washers, this is THE bodge artist way of doing it, I'll probably get round to sorting it one day.......
.....if I can be bothered.
Edited by Robert1234
  • 3 weeks later...
Update on this - did the job, fitted a pair of gmax mini shocks and cut the towers down - the ride is now like a magic carpet in comparison! Now here's the confusing bit :/ the ride height on the passenger side has dropped about another inch! Now before, there was a minuscule amount of travel - maybe 1/8 of an inch at most but there WAS travel ie: the spring was holding up the car, (just) and not the bump stop.... So how has it happened?! It's now lopsided scrubs the arch on one side when parking :/
