P8lss Posted March 13, 2014 Share Posted March 13, 2014 Can anyone help me I have been restoring my gte coupe for a year or so now and I have changed nearly all the components in the engine bay,but she still does not start and idol...like she is running out of fuel,put new injectors,service parts,starter motor,altnator,ignition module,ht leads,rotor arm,I even put a new fuel pump on , but revs up , pops and dies,,, Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted March 13, 2014 Share Posted March 13, 2014 Sounds like the leads aren't in the correct order or the dizzy is in 180 degree out Quote Link to comment Share on other sites More sharing options...
P8lss Posted March 13, 2014 Author Share Posted March 13, 2014 Thanks m8 but, had new leads on and had dizzy checked, she starts up on the key but as soon as you put your foot on gas peddle she pops and farts and dies. Like its starving of fuel.do you know if they have a fuel relay and were it's located. Quote Link to comment Share on other sites More sharing options...
Devil Fish Posted March 13, 2014 Share Posted March 13, 2014 Vacuum leak? Quote Link to comment Share on other sites More sharing options...
garymanc Posted March 13, 2014 Share Posted March 13, 2014 (edited) fuel pump relay , were abouts in Manchester are you Edited March 13, 2014 by garymanc Quote Link to comment Share on other sites More sharing options...
kbomgte Posted March 13, 2014 Share Posted March 13, 2014 Feul filter going into the feul pump from tank Quote Link to comment Share on other sites More sharing options...
monaco ray Posted March 13, 2014 Share Posted March 13, 2014 Hi, just a thought but is the airflow trunking connected to intake manifold securely and also the wiring harness plug on the airflow meter properly fitted. Remove the harness plug and make sure the pins are clean, its worth a look. Quote Link to comment Share on other sites More sharing options...
dog321fish Posted March 14, 2014 Share Posted March 14, 2014 Maybe obvious but have you put any fresh petrol in it ? fuel does seem to "go off". Quote Link to comment Share on other sites More sharing options...
®evo03 Posted March 14, 2014 Share Posted March 14, 2014 Check fuel lines, if GTE fuel injection, are right way round. Haynes manual is wrong! woooops feed from pump goes direct to t piece on fuel injection rail, FEED the return is regulated, regulatory is fitted to injection rail that feeds the injectors. RETURN 1 Quote Link to comment Share on other sites More sharing options...
P8lss Posted March 16, 2014 Author Share Posted March 16, 2014 fuel pump relay , were abouts in Manchester are you Quote Link to comment Share on other sites More sharing options...
P8lss Posted March 16, 2014 Author Share Posted March 16, 2014 Thank you 4 your help,but we're is the fuel pump relay located,,,I am in crumpsall near Cheatham hill. Quote Link to comment Share on other sites More sharing options...
garymanc Posted March 16, 2014 Share Posted March 16, 2014 i think the relay is on the inner wings on 2.0 engine , if your still stuck with it not running in a few weeks i will come and see if i can help 1 Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted March 16, 2014 Share Posted March 16, 2014 Check engine earth also. Probably wont be it, but its worth checking if you havent done so already. Quote Link to comment Share on other sites More sharing options...
P8lss Posted April 14, 2014 Author Share Posted April 14, 2014 Hi guys,update on my car? Fitted a airflow metre on her and put new fuel regulator on,but still having the same problem,we're as when you turn her over she pops and farts and dies,need help!!! Got her booked in garage to do 2 little rust spots on the passenger footwell,but can't do that until she is running right. Quote Link to comment Share on other sites More sharing options...
