Injector Mount Seals
moodoo
Hi all..bit of a longshot...
Has anyone got the 4 'square' O-rings that seal the injector tip to the mounting plate on the inlet manifold on a GTE (or similar Jetronic system)? There are 4 larger seals a bit further up, which are for locating the injector, I have those, but I don't have the smaller lower ones which seal the injector in.
Thanks in advance...
I have a draw of manta gaskets left from headgasket sets etc and have 4 I think are the injector seals.
Been a while since i fitted any and i don't have a cih injector and mount around to check against.
They are 13mm outside 8mm inside and 4mm high approx Square edged o rings.
Is that what you need?
Yes, it's those smaller ones. I have the large ones, and the gaskets, just need the small ones. I measured 15 x 9 x 5, but the ones I have are knackered, so mantasrme I'd say you're spot on. I'll pm you about getting you sorted for them, I presume you're ok to post them? Thanks. Fin
Yes can post them.
Yes can post them.
I thought the only 'O' ring as such you got in the head set was for the oilway. You fit this with the head gasket.
I have never seen the injector seals in a headset. Even in the genuine headset i bought a few years ago at billing from OCP.
Thanks
No, I don't believe they would come in the headset, it wouldn't make sense that way. The little round seal for the top of the timing cover that comes in a headset does look similar though, but I'm pretty sure David would know the difference! The injector seals are smaller than that seal anyway.
Didn't say they came from a headgasket set, I said I had a draw of manta gaskets left from head sets ETC
No idea where they came from, must have come in some kit if id have bought them separately I'd have used them.
If I could remember where half the stuff I have came from I'd be doing well (but I can't)
Yes they are smaller and thinner than the one for the oil way. Got a couple of those.
They're in an envelope and will be posted tomorrow.
