mantaray Posted April 27, 2015 Share Posted April 27, 2015 Urgent help needed. I am in the process of doing an auto to manual box conversion and have come up with a problem. It turns out that Opel changed the crank and flywheel on the 1800 Manta part way through production. Early 1800s ( before engine no 14159465) have a 40mm locating hole in the flywheel and 9mm bolts but the later ones ( after 14159466) have a 39mm hole and 10mm bolts. I urgently need an early 1800 manual flywheel and mounting bolts, if any one can help. Thanks. Link to comment Share on other sites More sharing options...
paulmanta Posted April 27, 2015 Share Posted April 27, 2015 Chris, I have a lot of flywheels here and I will measure one tomorrow, as for bolts I need to know if they have a shoulder and if the thread is very fine ? What size heads do they use and what kind of head (6 sided or that odd multi sided sort you often find on GM stuff ? Link to comment Share on other sites More sharing options...
Snowy Posted April 27, 2015 Share Posted April 27, 2015 Are these what you want?? http://www.autovaux.co.uk/product/90511423-screwhexhead.aspx Link to comment Share on other sites More sharing options...
paulmanta Posted April 27, 2015 Share Posted April 27, 2015 I hope so, I have bags of them ! That thread does not look fine enough though... Link to comment Share on other sites More sharing options...
Snowy Posted April 27, 2015 Share Posted April 27, 2015 I hope so, I have bags of them ! That thread does not look fine enough though... It is what I bought for my 1800, they fitted ok. Link to comment Share on other sites More sharing options...
brianm Posted April 27, 2015 Share Posted April 27, 2015 I have a 18s engine in the garage still with the fly wheel on it came out of an A reg engine no is 14059009 think this is what your after Link to comment Share on other sites More sharing options...
mantaray Posted April 27, 2015 Author Share Posted April 27, 2015 Snowy. Are they M10 or M9 bolts ? Paul. Msm sent. Brianm. Thanks for the offer, I'll see what I can find but may get back to you, would you sell just the flywheel and bolts if Paul can't help. Link to comment Share on other sites More sharing options...
brianm Posted April 27, 2015 Share Posted April 27, 2015 No problem ,whatever you need Link to comment Share on other sites More sharing options...
Snowy Posted April 28, 2015 Share Posted April 28, 2015 Snowy. Are they M10 or M9 bolts ? Paul. Msm sent. Brianm. Thanks for the offer, I'll see what I can find but may get back to you, would you sell just the flywheel and bolts if Paul can't help. Sorry, I just bought them and fitted them. Link to comment Share on other sites More sharing options...
Snowy Posted April 28, 2015 Share Posted April 28, 2015 If they aren't plenty of other car makers used M9 http://www.ebay.co.uk/itm/Peugeot-Citroen-New-genuine-rep-flywheel-bolt-M9-x-1-0-x-22mm-Long-053713-/221612900354?pt=LH_DefaultDomain_3&hash=item3399288002 There is only one of these but if you just search for an M9 flywheel bolt I'm sure you will find plenty more. Link to comment Share on other sites More sharing options...
rutts Posted April 29, 2015 Share Posted April 29, 2015 Auto crank has fine thread. You can buy longer fine threaded bolts for this fitment from vauxhall dealer. converted my auto to manual years ago. Link to comment Share on other sites More sharing options...
mantaray Posted April 29, 2015 Author Share Posted April 29, 2015 Thanks to Paul Newport, I have now hopefully got an early flywheel and bolts. Thank you to all those you have offered help, this is why I have been a member of the OMOC for the past 25 years. A geart club with great members. Link to comment Share on other sites More sharing options...
