Ems Posted July 25, 2015 Share Posted July 25, 2015 I connected the dash for the first time today and the oil pressure at idle is 5+. The pump was stripped, checked and uprated during the rebuild with a SBD nylon relief valve also fitted. Is the valve likely to be stuck or do I need to remove some washers? Thanks Quote Link to comment Share on other sites More sharing options...
Retromanta1972 Posted July 26, 2015 Share Posted July 26, 2015 Did you add all the washers in the kit front and back of spring Fitted this kit as I was having same problem with new standard oil pump now with kit fitted have 60-80 on start up a 25 on idle 50 whilst driving Standard xe oil pressure is 20 on idle and 50-60 on start up Believe you can add more washers have hear of people getting 100 oil pressure which will cause more problems sounds great but reality will not help You will need to take plunger out and stick your finger up and make sure there are no burns in the opening your can emery the plunger down or the channel opening with 1200 wet and dry Quote Link to comment Share on other sites More sharing options...
Retromanta1972 Posted July 26, 2015 Share Posted July 26, 2015 Forget to mention you should retain 5 oil pressure on gauge pre start up as the pressure is made mainly from the gap between the shells and journals not necessary the oil itself strange but true engine need to retain some oil pressure to prevent damage on start up Pump just gets it around in close system If you have rwd not an easy job to reshell with engine out if washer or sticking plunger is not the cure 1 Quote Link to comment Share on other sites More sharing options...
Ems Posted July 26, 2015 Author Share Posted July 26, 2015 The engine has just been rebuilt with new bearings, arp bolts, etc. The Manta B gauge reads in bar so 5 which is the maximum on the gauge is around 72psi, the pressure has to be higher as the needle flickers between 5 and the end of the gauge. I'll have to check if the valve is stuck, if not maybe I'll take out a washer Quote Link to comment Share on other sites More sharing options...
mickappy Posted July 26, 2015 Share Posted July 26, 2015 id be putting a propper oil gauge in if i was you, 60 cold and about 20ish on idle warm.. don't believe the manta gauge. Quote Link to comment Share on other sites More sharing options...
Ems Posted July 30, 2015 Author Share Posted July 30, 2015 (edited) Looks like it was a loose connection, tightened the nut and oil pressure is 3.5 - 4 bar idle and 5 bar at higher revs. Biggest worry now is a big oil leak at the front, it's coming from above the sump gasket, - all gaskets etc are new! Edited July 30, 2015 by Ems Quote Link to comment Share on other sites More sharing options...
Snowy Posted July 30, 2015 Share Posted July 30, 2015 Front crank seal? Quote Link to comment Share on other sites More sharing options...
®evo03 Posted July 30, 2015 Share Posted July 30, 2015 Get the eeetabix in, that front bolt holding the pulley is ... tight!, goodluck! When u get time change back in too, usually original seals, can be 25 yr old, ish! Quote Link to comment Share on other sites More sharing options...
mickappy Posted July 31, 2015 Share Posted July 31, 2015 if the oil seal is new on the pump it shouldnt be that, id take the pully cover off and the rear cover and see if its lesking down ftom the cam cover behind the cam pulleys, if its the rear pump seal it should just nip up.. also check crank sensor. theses always leak snd its not too far from the pump.. ptfe tape this in. good luck.. xes do like to leave a mark Quote Link to comment Share on other sites More sharing options...
Ems Posted July 31, 2015 Author Share Posted July 31, 2015 I think the engine is in competition with my dog for marking its territory. Hopefully it's a case of just tightening some bolts, every gasket, etc on the engine is new. Quote Link to comment Share on other sites More sharing options...
Snowy Posted July 31, 2015 Share Posted July 31, 2015 I think the engine is in competition with my dog for marking its territory. Hopefully it's a case of just tightening some bolts, every gasket, etc on the engine is new. It is very easy to damage the front crank seal when installing it. I've done it. Doesn't half cause a leak. Quote Link to comment Share on other sites More sharing options...
Ems Posted July 31, 2015 Author Share Posted July 31, 2015 Can the crank seal be changed without removing the oil pump? Quote Link to comment Share on other sites More sharing options...
mickappy Posted July 31, 2015 Share Posted July 31, 2015 yep. Quote Link to comment Share on other sites More sharing options...
