Dave1958 Posted April 22, 2019 Share Posted April 22, 2019 Hi I need an stock exhaust for a 79 Manta srb Coupe 100bhp) auto Every online seller seems to be in Germany and tell you that their product “should” fit a LHD or RHD . When you press them for confirmation they just say they “can’t guarantee it fits”.so I’m wasting my time I don’t want to have to change manifolds or alter a LHD unit . I also don’t really want a Sportex as I believe they are really loud and as the car is stock a 3” tail pipe would probably look a bit boy racerish ( no offence meant ) So can I source one in the UK for a RHD car ? . I also need the M9x 1.25 bolts as they either bent when they came out or snapped off ( took hours to drill 2 out ) Aprreciate any help , please David Quote Link to comment Share on other sites More sharing options...
400PEL Posted April 22, 2019 Share Posted April 22, 2019 Hi Lhd manifold has flange running left to right. Rhd manifold has flange running front to back. Your best bet is to try and find Rhd manifold. Quote Link to comment Share on other sites More sharing options...
Dave1958 Posted April 22, 2019 Author Share Posted April 22, 2019 Hi Sorry didn’t understand . I have the RHD manifold on the car which runs north south on the car as you rightly say . My question is why can’t you buy a stock exhaust for a RHD car ? I assume you meant buy a LHD manifold that runs side to side . If I did do this will it fit when turned and fitted on the steering wheel side of my RHD car Just don’t understand why you can’t buy a pattern exhaust for a UK car . And the bolts are impossible to find . Any suggestions on sourcing ? Anybody got a used presilencer section that I can buy as the other boxes are obtainable as they are not handed Dave Quote Link to comment Share on other sites More sharing options...
400PEL Posted April 22, 2019 Share Posted April 22, 2019 Hi You will need a RHD manifold. The reason for the pattern LHD manifolds being readily available is Manta s were more popular in Europe and have a larger spares availability. Your best hope is to find a good second hand RHD manifold in Britain. Your on the best site to find one. Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted April 23, 2019 Share Posted April 23, 2019 Hi. Yes the standard replacement exhausts are now very hard to find. Front pipe can be fitted from a 1.6,1.9 or 2 litre depending on what you find .only difference there is an additional silencer on the 2 litre ones otherwise fully interchangeable. a few years back you could get them at any of the exhaust centres or on line but now it seems to be only old stock by asking around or a good used one. If the actual pipes up to the manifold after the y joint are ok you may have to fabricate a centre section yourself if no one has one.not too complicated a shape ,basically a straight section with a slight bend at the rear. Add an inline box if you wish.( sounds better/ quieter with it). Quote Link to comment Share on other sites More sharing options...
Dave1958 Posted April 23, 2019 Author Share Posted April 23, 2019 Hi I don’t have the downpipes as they were rotted out so I need a replacement set . Do you know if I need a specific set of downpipes to suit the autobox clearance ? Nobody seems to know if there is a difference ? If they are different then I’m looking for a rare used set and off an autobox car . I must say I’m close to selling the project on as sourcing parts is much more of a problem than I ever expected . So Auto/manual any difference in downpipe set ? Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted April 25, 2019 Share Posted April 25, 2019 No difference Il keep a lookout. Surely someone must have a front section that’s ok. The double pipes that run up to the manifold rarely rust it’s usually the lower bit after the y joint but a lot will have been thrown away because of that.when realy that bit is easy to mend. Quote Link to comment Share on other sites More sharing options...
rutts Posted April 25, 2019 Share Posted April 25, 2019 Auto is different. Part number differs. Or it does on the ascona b. Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted April 26, 2019 Share Posted April 26, 2019 Can’t see why. I have a manual and an auto and the front pipes are the same.who knows why the part number is different.the manifold is the same and so is the steering linkage that it passes so cannot see any other reasons ? Quote Link to comment Share on other sites More sharing options...
Dave1958 Posted April 27, 2019 Author Share Posted April 27, 2019 Hi Thanks for your help Hopefully somebody will break one and have an exhaust that I can fit or adapt . David Quote Link to comment Share on other sites More sharing options...
1900SR Posted April 27, 2019 Share Posted April 27, 2019 If you can't find one how about getting a stainless one made up? Quote Link to comment Share on other sites More sharing options...
Dave1958 Posted April 27, 2019 Author Share Posted April 27, 2019 I could but would have to trailer the car to the workshop . Works out quite expensive when I’m just doing a standard restoration . I will see if a used one turns up , if not I will use a Sportex and adapt it . Next time I will know to repair the old one !! thanks Quote Link to comment Share on other sites More sharing options...
Iain Posted April 29, 2019 Share Posted April 29, 2019 I found Sportex very helpful, I also didn't want the 3 inch tailpipe so asked them to make it look OEM and they obliged, however I did go for the standard system it is quite loud when accelerating hard but not too bad when driving "normally". Maybe worth a call they might be able to add an additional silencer ! Quote Link to comment Share on other sites More sharing options...
