JeffShaw Posted September 13, 2020 Share Posted September 13, 2020 Hi all, these were in a bag labelled window fittings. Has anyone any ides where they go or if they are even required Cheers Quote Link to comment Share on other sites More sharing options...
H-400 Posted September 13, 2020 Share Posted September 13, 2020 Those are parts of the window mecanism in the door. Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted September 13, 2020 Share Posted September 13, 2020 Certainly are and whilst technically they won't stop the window opening and closing they are for the limit stops so you should realy fit them if you can and spend a little time adjusting tHem to their best position Quote Link to comment Share on other sites More sharing options...
JeffShaw Posted September 13, 2020 Author Share Posted September 13, 2020 cheers would anyone have a pic of where exactly they go. Cheers Quote Link to comment Share on other sites More sharing options...
®evo03 Posted September 13, 2020 Share Posted September 13, 2020 Jeff with the window wound up and the door can off, u will figure it out. From memory, think they bolt to the window runners. Quote Link to comment Share on other sites More sharing options...
mantasrme Posted September 14, 2020 Share Posted September 14, 2020 They bolt to the inside of the door at the top. About an inch down from the top and about 1/4 3/4 along the length of the glass you will see a round hole with a slotted bolt hole inside it. The L brackets go inside the door with the bolt through the slot and the rubber feet down and in. They limit the up travel of the window by the rubber part sitting against the ends of the metal rail at the bottom of the glass. 2 Quote Link to comment Share on other sites More sharing options...
®evo03 Posted September 14, 2020 Share Posted September 14, 2020 Thats it ! Quote Link to comment Share on other sites More sharing options...
JeffShaw Posted September 15, 2020 Author Share Posted September 15, 2020 cheers lads much appreciated Quote Link to comment Share on other sites More sharing options...
