door pin removal tool
stumpy
Just a warning, I got one (cranked) off eBay and they snapped Way too easily. Used to have a Sykes Pickavant that did loads of pins without issue
The roll pins are are about 6mm , but the tool should come with a selection of thumb nuts to suit various sizes
edit.
Tool number for SP is 045400
Edited by Jessopia74
Added SP tool number
7 minutes ago, cam.in.head said:
Yes the cheap pins break.
What I did was order some good ones through advice of local body shop ( they may well be Sykes pickavant)and then made the knocking bar myself.the one in the kit is usually too short to be of use especially with tight pins
That is a good point and idea. I extended mine with a bit of round tube as another option.
