hoobby Posted April 10, 2021 Share Posted April 10, 2021 Had this jack 5 years filled and bleed as instructions but if fully raised will lower to about halfway with me standing on it think there is an internal seal problem ?. Quote Link to comment Share on other sites More sharing options...
Buz Posted April 10, 2021 Share Posted April 10, 2021 Sounds like either too much oil , but then you have checked it , or a mechanical blockage. I would drain some oil out first and see if it goes down. If not you need to see if it’s the cylinder or the mechanism that’s stopping it. I had a similar thing with my sealey one and turned out to be a small piece of gravel stopping it Does it go down at all and is it only faulty if raised fully Quote Link to comment Share on other sites More sharing options...
hoobby Posted April 10, 2021 Author Share Posted April 10, 2021 (edited) This jack (high lift) will only lift a car halfway and hold the weight but refuses to lift any further it lifts but keeps droping back down as if you have reached the maximum lift will not hold weight on maximum lift but will drop to halfway down and hold weight Edited April 10, 2021 by hoobby Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted April 10, 2021 Share Posted April 10, 2021 Sounds like it's lost oil mate. But IMHO Bin it, too dangerous and not worth the risk. 1 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted April 10, 2021 Share Posted April 10, 2021 8 minutes ago, Jessopia74 said: Sounds like it's lost oil mate. But IMHO Bin it, too dangerous and not worth the risk. Agree to easy to lose your life, You can get a low lift jack of eBay for £109 ,better be safe 2 Quote Link to comment Share on other sites More sharing options...
hoobby Posted April 10, 2021 Author Share Posted April 10, 2021 16 minutes ago, Jessopia74 said: too dangerous and not worth the risk Don't worry I don't trust it at all then again I never trust any jack I always use axle stands before getting underneath or removing wheels shame I only used it a few times. 2 Quote Link to comment Share on other sites More sharing options...
