Sutty2006 Posted May 20, 2021 Share Posted May 20, 2021 Are there two different clutch cables for Mantas? Reason I ask, my 5 speed has a threaded rod with a lock nut on the end. Happy. But the B series has an old cable on with a domed end, and a new cable I have has the same dome end on it..... is it right? If so, how does it attach to the clutch arm? this is the end I’ve got. And is a clutch cable on eBay listed as Manta B. Quote Link to comment Share on other sites More sharing options...
Exclusive Opel Posted May 20, 2021 Share Posted May 20, 2021 Don't know if these will help. Quote Link to comment Share on other sites More sharing options...
Snowy Posted May 20, 2021 Share Posted May 20, 2021 24 minutes ago, Sutty2006 said: Are there two different clutch cables for Mantas? Reason I ask, my 5 speed has a threaded rod with a lock nut on the end. Happy. But the B series has an old cable on with a domed end, and a new cable I have has the same dome end on it..... is it right? If so, how does it attach to the clutch arm? this is the end I’ve got. And is a clutch cable on eBay listed as Manta B. It depends on your gearbox clutch arm. Early ones had the adjustment at the bulkhead with the domed end, later four speed gearboxes had a similar set up to the five speed with the adjustment at the gearbox end using the threaded rod. Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted May 20, 2021 Author Share Posted May 20, 2021 28 minutes ago, Snowy said: It depends on your gearbox clutch arm. Early ones had the adjustment at the bulkhead with the domed end, later four speed gearboxes had a similar set up to the five speed with the adjustment at the gearbox end using the threaded rod. Interesting. I bet I have the later arm, as it’s just a hole in it, for the threaded rod to go through. I can’t see a way of attaching the domed cable end to the clutch arm, nor that picture up top, I just can’t see a way of getting it to attach. At a guess, the early arm must have a slit in it to allow the domed end to hook over. Quote Link to comment Share on other sites More sharing options...
Snowy Posted May 21, 2021 Share Posted May 21, 2021 13 hours ago, Sutty2006 said: Interesting. I bet I have the later arm, as it’s just a hole in it, for the threaded rod to go through. I can’t see a way of attaching the domed cable end to the clutch arm, nor that picture up top, I just can’t see a way of getting it to attach. At a guess, the early arm must have a slit in it to allow the domed end to hook over. Yes the early type had what's easiest to describe as a key style slot with the small part domed to match the cable. So you push the dome through the large opening and slid across into the smaller domed recess. The adjustment was at the bulkhead using the same method of adjustment as a GTE throttle cable. A C clip and a ribbed metal outer for it to clip into. 1 Quote Link to comment Share on other sites More sharing options...
rutts Posted May 21, 2021 Share Posted May 21, 2021 There are a few different cables for manta b with threaded end for clutch fork. GTE is different from 1.8 even though they are same gearbox in reality. Some are longer on the thread end. Can't remember which one is longest. Look for GM part numbers. 1 Quote Link to comment Share on other sites More sharing options...
