Jonathan Pounsett Posted June 8, 2021 Share Posted June 8, 2021 What holds the door check straps to the A post? Is it a bolt or a pin? Thanks Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted June 8, 2021 Share Posted June 8, 2021 IIRC it is a mushroom shaped semi rivet. The bottom slightly flared , comes out the top. 1 Quote Link to comment Share on other sites More sharing options...
stumpy Posted June 8, 2021 Share Posted June 8, 2021 tried everything toget mine out was a basted so out come the grinder and chop chop chop tbf the doors were scrap anyway on mine 1 Quote Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted June 8, 2021 Author Share Posted June 8, 2021 Thanks Jess. Got it. Next question - where might I get a couple of those? Does anyone know their diameter and length? Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted June 8, 2021 Share Posted June 8, 2021 The best replacement I used was from a friend, he got me something that was an airframe rivet, was anodise aluminium and flared perfectly with air hammer. I know there are copper thing that are similar, but I just use a cotter pins and drill them just under the bottom flange and chop off any excess for neatness, but not really necessary tbh. Talking about these things https://www.westernwelt.com/Cotter-Pin-and-Axes-2-pices-each 1 Quote Link to comment Share on other sites More sharing options...
Exclusive Opel Posted June 8, 2021 Share Posted June 8, 2021 I've just got standard solid rivets in mine. Just dropped in, not flared or anything. Been there for twenty+ years and never fallen out. 2 Quote Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted June 8, 2021 Author Share Posted June 8, 2021 I was looking at the pin that goes through the bonnet safety catch. It’s similar. A domed head and a hollow shaft squashed flat to stop it dropping out. I never really looked at it before but it does the job. Simple and effective. 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted June 8, 2021 Share Posted June 8, 2021 29 minutes ago, Jonathan Pounsett said: I was looking at the pin that goes through the bonnet safety catch. It’s similar. A domed head and a hollow shaft squashed flat to stop it dropping out. I never really looked at it before but it does the job. Simple and effective. Think that's good enough 1 Quote Link to comment Share on other sites More sharing options...
mantasrme Posted June 8, 2021 Share Posted June 8, 2021 Original style rivets available from https://www.edelschmiede.com/shop/Button-head-rivet-for-door-stop-Opel-rear-wheel-drive 1 1 Quote Link to comment Share on other sites More sharing options...
Mickfrad Posted June 8, 2021 Share Posted June 8, 2021 I just used a Clevis pin a bit long but easy to remove if I need to. https://www.ebay.co.uk/itm/Clevis-Pins-M4-4mm-M5-5mm-Dia-Stainless-Steel-R-Clips-Washers-10mm-to-50mm-x2-/323993236762?_trksid=p2349624.m46890.l49286 1 1 Quote Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted June 9, 2021 Author Share Posted June 9, 2021 20 hours ago, mantasrme said: Original style rivets available from https://www.edelschmiede.com/shop/Button-head-rivet-for-door-stop-Opel-rear-wheel-drive Thanks. I’ll order some now. I hope they don’t send left-hand drive ones. Second thoughts I’ll get some clevis pins. Shipping from Edelschmiede killed it! 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted June 9, 2021 Share Posted June 9, 2021 2 hours ago, Jonathan Pounsett said: I hope they don’t send left-hand drive ones. 👍😂😂 Quote Link to comment Share on other sites More sharing options...
