Snowy Posted July 4, 2021 Share Posted July 4, 2021 I'm going to run my CIH on fuel injection but while I collect all the parts I need I will stick it on a carb. So does anyone have a carb manifold for a 2L CIH, as complete as possible would be great. Thanks Link to comment Share on other sites More sharing options...
®evo03 Posted July 4, 2021 Share Posted July 4, 2021 Are the standard inlet manifolds different, depending on carb? Take it, its standard inlet and not side draughts? Link to comment Share on other sites More sharing options...
Snowy Posted July 5, 2021 Author Share Posted July 5, 2021 7 hours ago, ®evo03 said: Are the standard inlet manifolds different, depending on carb? Take it, its standard inlet and not side draughts? Yes, standard inlets are different depending on the carb type. But I'd be happy with any of them. Link to comment Share on other sites More sharing options...
Trooker Posted July 5, 2021 Share Posted July 5, 2021 Are you going for a modern fuel injection system? Link to comment Share on other sites More sharing options...
Snowy Posted July 5, 2021 Author Share Posted July 5, 2021 38 minutes ago, Trooker said: Are you going for a modern fuel injection system? Yes. So I'm deciding right now on what air mass meter etc I want to use. Also I want a Frontera 2.4 timing cover, which I think I've got sorted, so the crank sensor looks standard. So to get the car up and running I will use a carb while I collect all the bits. 1 Link to comment Share on other sites More sharing options...
Trooker Posted July 5, 2021 Share Posted July 5, 2021 35 minutes ago, Snowy said: Yes. So I'm deciding right now on what air mass meter etc I want to use. Also I want a Frontera 2.4 timing cover, which I think I've got sorted, so the crank sensor looks standard. So to get the car up and running I will use a carb while I collect all the bits. Excellent project, I hope you do a topic/thread on it. 🤞 Link to comment Share on other sites More sharing options...
Snowy Posted July 5, 2021 Author Share Posted July 5, 2021 2 hours ago, Trooker said: Excellent project, I hope you do a topic/thread on it. 🤞 I will, I did it years ago and the gains are good. What I cannot decide though is an extra 15bhp worth the £600 for high comp pistons Link to comment Share on other sites More sharing options...
Trooker Posted July 5, 2021 Share Posted July 5, 2021 1 hour ago, Snowy said: I will, I did it years ago and the gains are good. What I cannot decide though is an extra 15bhp worth the £600 for high comp pistons Excellent! £600 for pistons 😬 What will you regret most when it’s done though, spending the money or wondering ‘what if’ Only you can really answer that. Wisdom to you! Link to comment Share on other sites More sharing options...
Snowy Posted July 5, 2021 Author Share Posted July 5, 2021 2 hours ago, Trooker said: Excellent! £600 for pistons 😬 What will you regret most when it’s done though, spending the money or wondering ‘what if’ Only you can really answer that. Wisdom to you! I don't think I will miss it, if I wanted power I wouldn't be starting with a CIH. 1 Link to comment Share on other sites More sharing options...
Sutty2006 Posted July 5, 2021 Share Posted July 5, 2021 Yeah 600 notes isn’t worth 15hp lol. Put the cash to better use I would. 1 Link to comment Share on other sites More sharing options...
Snowy Posted July 5, 2021 Author Share Posted July 5, 2021 1 hour ago, Sutty2006 said: Yeah 600 notes isn’t worth 15hp lol. Put the cash to better use I would. You are correct! 1 Link to comment Share on other sites More sharing options...
