B series front indicator brackets.
Sutty2006
50 minutes ago, Sutty2006 said:
Looking at my 76 coupe, it had a front end welded on about 10 years ago. No idea why they didn’t save the indicator brackets. Does anyone have a rotten front end they can cut them off for me?
Yes, do you want both sides? I may even have some that I have already cut off an old cavalier.
Thanks
21 minutes ago, Sutty2006 said:
Yes please. Both sides are missing
No problem, I shall dig them out for you tomorrow. If I can't find the ones I've already cut off I will cut the ones off the yellow coupe. I've a NOS front end for that car.
  • Thanks 1
  • 7 months later...
33 minutes ago, Vince said:
How quick do you need these. Might be able to help next month when my donor shell comes home.
Is it a coupe shell? I might need another cut from the boot seal lip if it is. Not in a massive rush.
Hi Vince is the nearside boot hinge available and not bent or distorted
Eventually yes. It's a GTE hinge not an exclusive if that makes any difference?
  • Thanks 1
Yes same hinge saloon are different as I found out.
Just let me know when you have it.
Not sure if you know but the pivot shaft is splayed open you will have to drill it out.
IMG_20210530_123222.thumb.jpg.6e5fbc9ed6701251b73203ba8770c98e.jpg.53da5b583635361a65ae06eec92ac680.jpg
Or simply cut round it?😁
