B1 Gearbox conversion to manual
Kenny G
yes 3 speed auto is fine. except maybee on 1.6 models where it ends up a tad underpowered !
certainly no issues on the 2.2. it goes up into top quite soon and rarely needs to drop down a gear.
whatever gearbox that ends up in this conversion will work and plenty of advice here to help with it if needs be.
59 minutes ago, cam.in.head said:
its all personal preference realy. i hate the short throw 5 speed boxes and have yet to find a nicer gearchange feeling than the long lever 4 speed. but then i like an old car to have an original driving feel about it.
everyone to their own i suppose. no offence intended.
the later mantas ( with bodykit) suit the 5 speed but just doesnt feel right in a pre 82 car.
👍 agree
45 minutes ago, 1900SR said:
I'm kind of with Cam.in.head, I really like the 4 speed box. Mind you I liked the 3 speed auto on my 1900 Berlinetta as well.
Brilliant. Thanks 👍
13 hours ago, cam.in.head said:
i may even part with my box if youre struggling but im up in west yorks
Hi Cam, just seen your message, is your Box a four speed? All the parts I have been offered are miles away anyway. I would probably try and collect them all in one go on a weekend if I can plan it correctly. Shaun thinks he may have a consoul / prop etc. If you were to part with your box what would the price be?
Cheers
Kenny.
make me an offer ?
i have the 4 speed gearbox with bellhousing,lower cover,gearlever and gaiter,clutch fork.
i have the mounting crossmember ( rubber mounting may not be perfect but would fit until you found a better one)
flywheel and bolts,can give you a used clutch but you would probably want to fit new anyway.
you will need a crankshaft spigot bearing .i havnt got a spare one of those.
20 minutes ago, cam.in.head said:
make me an offer ?
He would probably need the clutch to get a refurb unit as new parts seem to be getting really hard to source.
make me an offer ?
Now I'm excited! Come on I'm new to the restro Manta scene although now in it for long term. Let me know what you know you want for it. 🤣. It would be going to a good home 👍. Would be putting new clutch and spigot in anyway.
Or recoditioned clutch, cheers Jessopia.
just looked on abay and theres a few clutch plates on there so no issues there. covers/pressure plates dont wear as much so can be usually reused.i do anyway !
there is also someone selling      clutch cable mounting rubbers    which you will need as part of your parts collection for the conversion.
they often split .
i will pm you .
Thanks to all who have replied to post, Good to see there is a helpful Manta community out there. I have hopefull now started my parts collection for this conversion thanks to cam.in.head 👍. Just waiting on another couple of the community looking in their sheds/shelves. I will post some pics on progress during conversion.
Thanks again to you all.
Kenny
from what i remember a 4 speed prop,5 speed and an auto are all different.only have 4 sp and auto to compare.
if you realy get stuck i do have allthe parts needed ( everything ) for the full conversion but would rather just sell the afiremoentioned ones in case i ever want to change mine back .
Guy,
Can't believe the response I had had for the parts required for this conversion. cam.in.head has agreed to give me everything as a job lot required for conversion. I will update on progress as I carry it out. I'm sure there will be other things / advise  I need going forward.
Thanks again, Glad there is such a thing as this club!
Kenny G
5 speed and 4 speed props are 100% different. Auto is different too, but as to where it sits in the scale of things not sure. But when I converted my 79 SRB some years ago from auto for 4 speed , needed different prop and then I got a 5 speed box, had to wait for a prop as I forgot about that. However by that point I had skipped my Auto prop. It’s not much. Couple of inches, but enough they can’t even be used temp.
My feeling is that the  Auto is the shortest, but I honestly could not be 100% on that one.
  • 2 months later...
Hi all,
Eventually have had time to get ready to carry out conversion to manual, split opinion on whether I should leave it original as is as it us going fine. I prefer manual and thanks to cam.in.head I have all the parts required to convert to 4 speed. I will update post on progres.
Kenny
  • Like 3
  • 3 weeks later...
Hi, Can anyone please tell me if my clutch pedal should have a return spring fitted? Strange how the pedal just seems to float on the shaft. Ready to fit modified pedal assembly but not sure regarding whether there should be a return spring at the clutch pedal or not??
Thanks
Kenny
I’ve found the auto box really good, smooth and punchy, kickdown is good too so I think I will leave it automatic for now and spend the money I’ve saved on other goodies, having said that I do like a good manual box :)
1 hour ago, Kenny G said:
Thank you,
Ref. the pedal just live on shaft? Is this correct? I feel like drilling shaft and fitting a split pin or something to stop pedal moving as much on shaft.
Kenny.
IIRC it should have a spring washer (wavey type), with a retaining clip
