Sutty2006 Posted May 25, 2022 Share Posted May 25, 2022 What kind of figures are we looking for on a 2.2 CIH compression test. Got 150 on cyl 1 then 125 on 2 but battery gone flat now. Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted May 25, 2022 Share Posted May 25, 2022 (edited) Rough way to figure it. 14.7psi x CR, think it’s about 9:1 on the 2,2 , so 14.7 x 9 = 132.3Psi So 150 is good, 125 is a tiny bit low, but serviceable. if it’s 10:1 the adjust accordingly. Edited May 25, 2022 by Jessopia74 1 Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted May 25, 2022 Share Posted May 25, 2022 it also depends on how accurate your tester is.or even what make it is too. i have used the same tester ( a gunsons one) since the 80's so can use it as a fair comparison over the years.between things it has tested. probably of no use realy but all good 2.0S engines tested around 180 psi per cyl and were 165-170 if the mileage was high ( over say 90000) engines with inlet valve seal leakage tested around 190-195 due to the carbon build up. i have 2 cars with the 2.2 in.(standard spec) one that has done 70000 measures 225 per cyl and the other that has done 150000 reads 215 psi. as far as i know the 2.2 and 2.0E are cr9.4:1 2 Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted May 25, 2022 Author Share Posted May 25, 2022 It’s a pretty decent snap on tester. I bought it years ago on offer but don’t work on petrols 🤣 I work on Diesel engines. I’ve done about 5 engines with it now. fresh battery and figures much better Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted May 25, 2022 Share Posted May 25, 2022 (edited) Nothing jumping out there mate. If you had one at 90psi on your gauge then it would be troubling. Can get cheap Bluetooth bore scopes now if you want to check wear/lip Edited May 25, 2022 by Jessopia74 Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted May 26, 2022 Author Share Posted May 26, 2022 11 hours ago, Jessopia74 said: Nothing jumping out there mate. If you had one at 90psi on your gauge then it would be troubling. Can get cheap Bluetooth bore scopes now if you want to check wear/lip I just did it out of curiosity. Bought a new project that’s not run for 14 years. 2 Quote Link to comment Share on other sites More sharing options...
Trooker Posted May 26, 2022 Share Posted May 26, 2022 28 minutes ago, Sutty2006 said: I just did it out of curiosity. Bought a new project that’s not run for 14 years. Not many of those left. Does it need much? Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted May 26, 2022 Author Share Posted May 26, 2022 3 hours ago, Trooker said: Not many of those left. Does it need much? Needs recommissioning. Fuel pipes are all shot. Then all fluids changing. Might need master cylinder refurbishing. Haven’t had much time to look at it but it seams pretty solid right now. Front strut tops are a little crusty. 1 Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted May 26, 2022 Share Posted May 26, 2022 if yours is a snap on then it most certainly is more accurate than mine.but mine is ok for comparison purposes. nice carlton. i have one the same in red. owned it since 94. the strut tops were a common thing even back in the day. when i got mine they were ok.just starting around the welds but no holes and much more important is the brace section underneath. thats the strength .i cut most of the top area away, protected the rest and then replaced the inner wing top with 1.5mm galv. the area hasnt needed touching since and is still perfect. great cars when right, not quite omega comfort but close ! 1 Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted May 26, 2022 Author Share Posted May 26, 2022 I’ve had an omega. 2002 2.6 saloon. Nice car but gave me horrendous back pain. Don’t know what it is about Vauxhalls, but every model apart from Carltons give me chronic back pain. Mantas not so much but do make my back stiff on long journeys. The worst, a 54 plate Astra sport held the record. 1.5 miles before it brought me to tears. Even the 1992 senator I had hurt. But Carltons? No. I can and have driven thousands of miles over a couple of days in them (600 miles in one day once) and could keep on going. Don’t know why!!!! Quote Link to comment Share on other sites More sharing options...
