mantasrme Posted October 28, 2022 Share Posted October 28, 2022 6 hours ago, Jessopia74 said: Is it the thickness of the manifold that differs? I see, to recall a mod with washers stacked, tacked on the edge and then cut with angle grinder back down to create a ledged washer. It was not on a manta but some other car that used a similar shared clamping bolt, perhaps mini. No its the width of the runners themselves thats the issue with the bolts. The standard hex heads with large washers don't have enough room because the side of the runner is further across. So its going to need the Cap head allen bolts that the 2.4's ran with smaller washers. Which are available from Edelschmeide as a set but don't seem available from the uk anywhere i've looked so far. I'm going to modify a couple of standard bolts just to hold it against the head in position so i can refit the bonnet and check for clearance. Because if that hits theres a whole lot of other problems to solve first. As long as it clears i'll move onto how to get a linkage onto the throttle spindle as it didn't come with anything and the setup looks different to both GT/e and 2.2 manifolds 2 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted October 28, 2022 Share Posted October 28, 2022 5 hours ago, mantasrme said: No its the width of the runners themselves thats the issue with the bolts. The standard hex heads with large washers don't have enough room because the side of the runner is further across. So its going to need the Cap head allen bolts that the 2.4's ran with smaller washers. Which are available from Edelschmeide as a set but don't seem available from the uk anywhere i've looked so far. I'm going to modify a couple of standard bolts just to hold it against the head in position so i can refit the bonnet and check for clearance. Because if that hits theres a whole lot of other problems to solve first. As long as it clears i'll move onto how to get a linkage onto the throttle spindle as it didn't come with anything and the setup looks different to both GT/e and 2.2 manifolds Ah! Makes sense now, and ofc them been of an oddity of size 🤦♂️ Quote Link to comment Share on other sites More sharing options...
GTEPETE Posted November 6, 2022 Author Share Posted November 6, 2022 Found some photos of my Chris B modded manifold..also managed to buy two new NOS throttle bodies off ebay to fit later, without paying high German prices...... 2 Quote Link to comment Share on other sites More sharing options...
execman Posted November 7, 2022 Share Posted November 7, 2022 hi Pete, what throttle linkage did you use please, as David Mantasport is having to make one up for my Monza manifold conversion? also the standard manifold bolts wont work with this setup as the heads are too big to clear the sides of the larger runners. The heads bolts are a 9mm diameter oddball size that aren't available in the UK, so these are being ordered from Mr Edelschmeide. Quote Link to comment Share on other sites More sharing options...
GTEPETE Posted November 7, 2022 Author Share Posted November 7, 2022 Haven't got that far...but planning to use something based on the 3.0 set up... Quote Link to comment Share on other sites More sharing options...
execman Posted November 7, 2022 Share Posted November 7, 2022 oh ok. good luck with yours. Quote Link to comment Share on other sites More sharing options...
