GTEPETE Posted December 19, 2022 Share Posted December 19, 2022 Looking at some spares I have in my shed, are these the correct wheel bearings for the front and rear? Fronts I think are Quinton Hazell - QWB155C Rears I think are Quinton Hazell - QWB177 / AP Lockheed WBK191...Does anyone have other manufacturer part numbers for the rear bearings please? I am planning to fit a pair of shortened Commodore 5 stud axles to the Manta housing. I will have to use a spacer/sleeve with the Manta bearing as Commodore shafts are smaller in diameter by about 5mm.... Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted December 19, 2022 Share Posted December 19, 2022 For good reference, manta front wheel bearings are the same as Corsa B rears. 2 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted December 19, 2022 Share Posted December 19, 2022 40 minutes ago, Sutty2006 said: For good reference, manta front wheel bearings are the same as Corsa B rears. Brilliant 👍 Quote Link to comment Share on other sites More sharing options...
H-400 Posted December 19, 2022 Share Posted December 19, 2022 Hi Pete, partnr's you gave give Deawoo and when I cross the Manta GSI they don't fit (says the PC). I'v got rear bearings of Quinton Hazel and they have the partnr. QWB236G. Can always measure them if you want. Bearings of SKF VKBA944 are front ones for Manta & Rekord and also as Sutty wrote rear bearings of Nova & Astra front wheel drive. SKF VKBA994 are rear commo, 400 and Rekord Sprint & Rekord Van SKF VKBA526 are also on my shelf and look to be Commo/Senator/400 front. If you don't find any rear bearings in the UK, google "radlagersatz hinten Manta B", still enough parts in Germany. I'm going the same route as you, using half shafts of a Commo and use a bush to fit original GSI bearings. Not sure I'm shortening them, have a spare rear axle so I can try with a distance plate so I'll have a wider rear axle. 1 2 Quote Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted December 19, 2022 Share Posted December 19, 2022 9 hours ago, GTEPETE said: Looking at some spares I have in my shed, are these the correct wheel bearings for the front and rear? Fronts I think are Quinton Hazell - QWB155C Rears I think are Quinton Hazell - QWB177 / AP Lockheed WBK191...Does anyone have other manufacturer part numbers for the rear bearings please? I am planning to fit a pair of shortened Commodore 5 stud axles to the Manta housing. I will have to use a spacer with the Manta bearing as Commodore shafts are smaller in diameter by about 5mm.... Have you got an FPS near you? When I did the same job I took the Commodore and in my case Monza bearings in and the guy found me better spec SKF bearings matching the diameters? They were really helpful and had the bearings I needed in stock. 1 Quote Link to comment Share on other sites More sharing options...
Moonmonkey Posted December 19, 2022 Share Posted December 19, 2022 (edited) Autodoc.co.uk are good for comparing part numbers and cars. The QWB155c is listed as an Opel Manta B amongst many other cars Edited December 19, 2022 by Moonmonkey Grammar 2 Quote Link to comment Share on other sites More sharing options...
H-400 Posted December 19, 2022 Share Posted December 19, 2022 1 hour ago, Moonmonkey said: The QWB155c is listed as an Opel Manta B 👍 Well done 👍 1 Quote Link to comment Share on other sites More sharing options...
GTEPETE Posted December 20, 2022 Author Share Posted December 20, 2022 Thanks for your advice guys...front bearings sorted (using TJM 5 stud front hubs). For info Manta rear bearings are 72mm dia x 41 x 20.5mm Commodore bearings are 73mm dia x 36.3mm x 25mm 3 Quote Link to comment Share on other sites More sharing options...
GTEPETE Posted December 20, 2022 Author Share Posted December 20, 2022 Just come across this shaft on ebay, I assume its a 5 stud, but looks different to my one (which had discs). Are shafts fitted to drum axled Commodores different to disc brake ones ie are disc brake axle shafts longer as has the cast caliper mounting rather than a pressed steel retainer to hold the axle in the housing? https://www.ebay.co.uk/itm/255461252849?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D244527%26meid%3Db6608f7c748742a38213245cc7dc97f6%26pid%3D101195%26rk%3D5%26rkt%3D12%26sd%3D163459219561%26itm%3D255461252849%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DSimplAMLv11WebTrimmedV3MskuAspectsV202110NoVariantSeedKnnRecallV1&_trksid=p2047675.c101195.m1851&amdata=cksum%3A255461252849b6608f7c748742a38213245cc7dc97f6|enc%3AAQAHAAABIMFr2e4EmAnM%2ByHZkULYKDIJ4L66fOjNL0iupgt%2BzO1%2F3AE1t3mNirUYB96NktMCicMagiS6mbeTl0xquGODv9mHeyl6SBCJjCGb9V%2BXhvNYPAaeLUv9AVhH2quZ9YAF2VDqVygRS7eqX0nfMgwA4JWtMvNtXjooGnCxoRCiduqzlWWo5bBoWHnM3qTgx%2F%2BdEQJGG0n%2FklmuZdikjeh7zUsrYjml%2FyrZdhcukjMPZIfjHwt%2FQlp%2Bf0D%2BEyzCa%2FEhQS0n1MY3%2B%2Fy7bSAkLWdTi0e09n2tVPkPLPJ6xoI1RevNoxb8%2FKS5ve2d2%2Bs4%2FbAW7HuR6nKpJhO3VYwHEQRHgdcitm1l3gpVPlTa87dxvVNjWtpmZl28utXeDobgBQRHAQ%3D%3D|ampid%3APL_CLK|clp%3A2047675 Quote Link to comment Share on other sites More sharing options...
Moonmonkey Posted December 20, 2022 Share Posted December 20, 2022 3 hours ago, GTEPETE said: Just come across this shaft on ebay, I assume its a 5 stud, but looks different to my one (which had discs). Are shafts fitted to drum axled Commodores different to disc brake ones ie are disc brake axle shafts longer as has the cast caliper mounting rather than a pressed steel retainer to hold the axle in the housing? I think they might have fitted drums to the smaller engined Commodores, as I remember working on a mates 2.5 Vauxhall Viceroy which I think were based on a Commodore, and the Viceroy definitely had drum rear brakes and 5 stud wheels. 1 Quote Link to comment Share on other sites More sharing options...
H-400 Posted December 20, 2022 Share Posted December 20, 2022 The Commo's had drums on the less powered ones. Those drums have the same diameter as the Manta's drums. Bought myself a set of 5 stud drums cause in Belgium we are not allowed to retrofit discs when drums are original. Mot rules😪. Am not sure about the difference between the halfshafts, was also thinking on that big cast piece on the end of the axle... 1 Quote Link to comment Share on other sites More sharing options...
