74009 Posted August 14, 2023 Share Posted August 14, 2023 Hi all, I'm looking for an Idle Control Valve for a standard 1986 2.0E GTE. Mine's been playing up for a while and it seems to be quite badly scored. Anyone happen to have one available please? Thanks, Stuart Link to comment Share on other sites More sharing options...
Sutty2006 Posted August 15, 2023 Share Posted August 15, 2023 Can you get the part number off it? I might have one floating about you can have. Link to comment Share on other sites More sharing options...
1200bandit Posted August 15, 2023 Share Posted August 15, 2023 Or take a photo that way everyone Will know what you are after Link to comment Share on other sites More sharing options...
Jessopia74 Posted August 15, 2023 Share Posted August 15, 2023 I’m guessing it’s the Auxiliary Air valve, as on the later Motronic the similar valve position dud control idle. Have a read of this, whilst it’s not 100% the same, the setup section for the valve is. Page18 for fast track to it. http://alfa-wahnsinn.de/L-jetronic-america_gtv6.pdf 1 Link to comment Share on other sites More sharing options...
1200bandit Posted August 16, 2023 Share Posted August 16, 2023 Some interesting information here Link to comment Share on other sites More sharing options...
MrCarlos Posted August 16, 2023 Share Posted August 16, 2023 I have good used valves available Link to comment Share on other sites More sharing options...
74009 Posted August 29, 2023 Author Share Posted August 29, 2023 (edited) Hi all, thanks for your replies - sorry for the slow response, had a bit of a busy couple of weeks. That was a very interesting document Jessopia74 - after following the instructions the car seems to be idling nicely again although I only had time for a quick test run today. I'm not sure if I'm fully out of the woods - it idled at 1000 rpm all the way from cold start to hot, except for when I stopped at one particular roundabout and it was nearer 1500 rpm - but oddly that only happened once. I think maybe I need to use some of the throttle cleaner on the throttle mechanism itself - it could be that it's not always returning fully to the idle position, and the matter of 1/2mm makes quite a difference. Edited August 29, 2023 by 74009 1 Link to comment Share on other sites More sharing options...
Jessopia74 Posted August 30, 2023 Share Posted August 30, 2023 Np, glad to see you have managed to make a little progress. They can look very complex to setup, but there are some good guides about that make setting up quite a simple process Link to comment Share on other sites More sharing options...
