redhatchrab Posted June 21 Share Posted June 21 Currently restoring Opel manta gte, engine has been rebuilt and fitted. Engine started no problem however stopped (manually) in a few minutes as no radiator fitted at the time. Now that the radiator is fitted and new fuel regulator valve has been fitted the engine will no longer start. Any ideas on what could be the problem? thanks Quote Link to comment Share on other sites More sharing options...
Mickfrad Posted June 21 Share Posted June 21 If it started before the fuel regulator was fitted that would be my first check. 1 Quote Link to comment Share on other sites More sharing options...
H-400 Posted June 21 Share Posted June 21 As mick mentioned above, check also the feul lines maybe you switched them. If everything looks ok spray some start pilot or brake cleaner into your manifold, if it runs for a second you know your ignition is OK. (don't spray in the AFM, backfire can ruin it) 1 Quote Link to comment Share on other sites More sharing options...
redhatchrab Posted June 21 Author Share Posted June 21 Thanks for those who have replied. The problem seems to be no vacuum at the fuel regulator to allow it to open. Any other ideas as to what could be causing this. Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted June 21 Share Posted June 21 47 minutes ago, redhatchrab said: Thanks for those who have replied. The problem seems to be no vacuum at the fuel regulator to allow it to open. Any other ideas as to what could be causing this. You don’t need any vacuum there. It’s open all the time even with vacuum pipe removed (high vacuum reduced the pressure slightly) 2 Quote Link to comment Share on other sites More sharing options...
®evo03 Posted June 21 Share Posted June 21 Hayes manual is wrong on fuel pipes, it's regulated on the return so it holds pressure in the rail. Also check earths are on. 2 Quote Link to comment Share on other sites More sharing options...
Rick H Posted June 24 Share Posted June 24 Had a similar problem with my GTE. Stopped it then it wouldn't start again (AAHHH!). After several key turns I realised I coudn't hear the pump, all fuses looked good but I gave them a waggle anyway. Waggled the 5th or 6th fuse from the left, the pump came alive & the engine started (Phew). Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted June 25 Share Posted June 25 As Rick said, check feed to fuel pump. You’ll need a spare pair of hands to turn the key as you check for voltage. If you don’t get any voltage, check your relay. It should be bolted to the right hand inner wheel arch. You can bypass it by putting a 2p piece between its fuse and the one next to it. If that works, you need to get your relay repaired. It’ll be a dry solder inside probably. 1 Quote Link to comment Share on other sites More sharing options...
