Camshaft bearings
Long shot but has anyone got a 4 piece set they would sell asap.
machine shop can only get 3 piece, head is sati waiting for them currently and they have only let me know today after 3 weeks of having having the head.
looking less likely this manta will make the VBOA at sywell
( know I can source from Europe but suppliers seem to be on holiday at the moment)
On 03/07/2024 at 13:22, Sutty2006 said:
Can you use the ones out of the head attached to my post box? 🤣
Wish I could lol, removing them pretty much destroys them being quite soft.
my guy has tracked some down now but gas to line bore them as they are unfinished ones
2 hours ago, mepbowles said:
Do you have to replace them when you do head work? I'd rather avoid the same hassle, I think my cams okay but want to do an unleaded conversion
All depends on how worn they are mate. Later heads that have the oil raiser on the drain at the back will definitely have suffered less than early ones without . If there is heavy wear on the bottom of the bearings, then replace is a good idea whilst you gave the head off.
  • Thanks 1
