Manta A Series V8 Supercharged
Paul Barrett
this is what I am not happy with, its still far from definitely working out as it is as an idea, I think a more proven way of an IRS system needs to be employed (hotrod/kitcar), which will work very well and look a lot better. I am pulling a lot of the ideas from what I've already done and using some of that parts. diff definitely, also I am concocting a way of using the bmw E28 shafts and hubs, but separating them into kitcar type hub carrier, rather like sierra stuff used by locost builders, but a little less flimsy looking (no offence intended to anyone, this isn't going to a super lightweight 2 seater).
the MX5 rear subframe is a good starting point as far as I can see for dimensions and arm angles, and I like its 'bolt on' design, which is what im going for I think.
CC9FC0CC-706B-43EC-B2CB-0B5112A146ED_zps
Trailing arm rear suspension works well, most modern rear wheel drive cars have it, Autograss racers building specials useing it because it gives excellent traction.
other suspension types might need upper arms which will mean huge intrusion into the rear of the body shell to accomodate them.
there is a whole can of worms to open here, putting a different suspension system in a car means things like all various wheel angles have to be calculated, like camber changes in roll, for which you need to calculate the roll centre, for this you are getting into the world of graphs and equations!
wel, bit of a waste of a day today, im so annoyed! bloody welder gun had decided to pack, wire feed is playing up due to the gas valve piece deciding to separate, only found this out after taking things apart around ten times!! so annoying as nowhere is open on a sat for this kind of stuff. hey ho.
on the upside found the bmw rear hubs I needed from my local oldschool BMW breaker guy. been doing tonnes of research and drawing for rear suspension and chassis builds, got steel sorted for it all too.
Also 'bit the bullet' and ordered a euro torch conversion kit for the welder, can't really afford it but need the welder working tip top for over Xmas break, read lots of recommendations for converting to euro spec with a decent gun for much better results.
EC0D73E2-3D13-4D35-B522-FD3A905AD1B5_zps
Edited by novashed
Be interesting to see how you get on with the epoxy paint. From my understanding of epoxy materials I hope it can cope with the impacts from road debris, but it sure as hell has got to be better than hammerite I once used on my suspension a few years back before I knew better.
some piccies, as always like to see everyone else's :) , few hours squeezed in today
e28/e34 (BMW 5 series basically) rear trailing arms, stripped down (huge 36mm hubnut to crack, a lot of whacking with big hammer and drifts to get bearing out etc
DC9E4191-21B4-47D6-9EDE-68F00F63A1A1_zps
about to be butchered
C315AB3B-2144-4303-9D6D-54EA7BAC4684_zps
bosh large holesaw onto pillar drill to cut some 3mm plate
E36EE888-07A1-4870-B086-0D5BC5D272EA_zps
voila
115FF619-CC73-4A42-9A7A-286BB7749FA4_zps
23AFA0E8-3065-4F99-9387-DDC3B6C9C4C3_zps
butchered hub carrier, needs more work cleaning up for welding, but my god there was so much steel to get through! I've got a giant iron filing anthill developing on the floor. this is the beginnings of an upright, im going to be using poly bushes the locost boys use for simplicity and easy/cheap parts source
B7A05EA6-E7A4-410F-B60B-B79C7A03818F_zps
Edited by novashed
Seems the welder eurotorch conversion has been successful, much better wire feed, had to wire in a gas solenoid valve too as originally was a manual valve in the torch itself, typical of a hobby light industrial welder. Going to get a new drum of wire too as have spotted some tiny rust spots on it which don't help with wire feed a getting a smooth weld bead.
Edited by novashed
Came home to find this bag of poly bushes for the rear end build, they are Haynes locost spec shore 80 hardness, little harder than I would of liked but for £30 for 14 I'm not complaining, just need track down some tube for the bush arrives now, I may have some already....
DD3AF15D-8C52-4291-9CD1-F591D1E094DA_zps
Well, I have made no progress with being ill for most if the holiday break. Only thing to report is that I've got hold of some alloys I want to use.most of you guys on here will not like but it's the 'pro touring' American look I'm kinda basing the build around
02738B5F-B951-49A1-A4FD-2038299D1A12_zps
They 17x10j rear and 17x8.5 fronts bmw 5x120 pattern, will fit the custom rear hubs fine, will either have to make some front hubs or use some adapter plates, will see further down the line
Edited by novashed
These new wheels are huge! Lol 265 or 275 wide tyre, can't wait to chop out the floor now.
00D828EA-4981-41D3-A29F-D5C8E5008C46_zps
The diff cradle is coming along nicely, measure measure measure weld, still warped a couple of mm out of square damn it!
C314D3E6-ABB0-4EF2-A3AA-EA369ED4A635_zps
1AA6A69B-48EB-45A5-A6E4-6082D7613503_zps
Uprights are done, but may need narrowing slightly due basing my measurements on a different wheel that isn't as thick walled as the above, easy fix.
664B32D0-8134-4D49-BB28-EBEAE7A512A1_zps
Edited by Paul Barrett
Correct tubing arrived for the bush casings, nice thick wall for a strong weld
D6FC1370-4115-414C-8A59-1C55DD8F6388_zps
Brackets also arrived too, had a crack at welding them on the cradle, measure measure again, tack it, measure then weld up
7DB5D92E-F8BE-4719-991F-04AF4F7275F6_zps
One bush bolted in to check all is ok, next up is a jig to make up the wishbones, can't wait!!
6E7A5FBE-FF6A-454B-80AF-0AA3638A69EC_zps
