My Opel Manta A 1.9S Luxus (1973)
costasa
Hi Samuel,
Them wheels look great, sorry about the Mirrors on ebay.
Ray.
Hello Ray
Thanks the wheels are beautifull and i think that it will be perfect to the manta :) .
No problem later i will find some mirros.
Samuel
  • 1 month later...
Hi Samuel,
That brake upgrade look great. And I love the ATS wheels.
Keep with the good work.
Hello Ricardo,
Thanks, the brakes inside the ATS looks wonderfull :D
Hi Samuel
That brake set up looks good ,gives me great ideas for mine ...keep it up :thumbup
Hello Rayman,
Thanks, hope to see what you gonna do in your beautifull manta:D
I was thinking on ats wheels for my A but didn't know the 13" would fit. I have the same brake setup as you.
Do the 7" fit in wheel arches ok without changing?
Wheels look great :thumbup
Yes they fit, a friend of mine have a manta with 13 ats 7'' with et 3 and he have the car lower 60/50 and don't touch
For me was a good surprise that the 13'' wheels work with this brake setup, i think that works because the et is 14,5 and the 7'' give more room inside the wheel.
Hey my friend!!!
Very good work!!:thumbup
MANTA thy will be beautiful!!!!!!!!!!!!:o
Best regards
Thanks BSilva,
Looking very Nice there Samuel - Keep up the great work ! :thumbup
Thanks Stonymanta,
The progress is slow but with time i gona pu the manta back in the road.
  • 4 weeks later...
Hello
Not much to say i just have bought some parts to my engine
Kent cam OP244 (290º hope that don't be to much high to my 1.9 )
Kent vernier pulley
Lexmaul valve springs (96-98kp)
And oil temp cooler valve from a moza(i have some questions about the temp that the stat opens)
only have pictures from the springs valves and the oil temp valve
Take with my mobile sorry the bad quality
I don't know if i'm going in a good way to improve my engine, any advice gonna be helpfull
I planing to buy a 13oiler cooler and electric fan
Buy new followers and large valves(45/40)
Port the head
Dont new shiny parts just make it worth it :thumbup
Yes is great the sensation :D
not wrong there rayman :thumbup
what a sense of satisfaction reassembling compared to stripping down
The satisfaction is great and gives more will to keep going :)
  • 2 months later...
Good 2011 to our Mantas
Not many news.
After reading some topics here and in retrorides i purchase a migwelder.
Hope to learn to weld and do some work in the Manta
Just bought a omp steering wheel
Hope that this year i have more time to work in the manta
Hello
Kent vernier pulley
Port the head
Costasa
The 244 cam is likely to touch the piston top due to the lift. You will need to have the pistons pocketed out to clear the valves, especially if you are using the 45mm inlets and 40mm exhausts. I had to do this on a 2.2 motor, any good engine shop will be able to do this.
Just for info the pockets were cut to a maximum depth of 6mm and the diameter was 48mm giving plenty of clearance for the valves. These were done on 2.2 pistons so you will need to check the thickness of the 1.9 piston crowns. Check opel gt forums for some good photos of pistons with pockets machined in.
Nice car by the way.
HTH
Chris
Costasa
HTH
Chris
Hello Chris,
Thanks for all advices, you really are a expert.
I will check the opelgt forum to see the pistons and engine tuning.
I was thinking to enlarge the engine block to 95mm and put this pistons in the photo it looks to have a good clearence to the valves
https://www.shopssl.de/epages/es125089.sf/de_DE/?ObjectPath=/Shops/es125089_KV-Carworld/Products/9140DA/SubProducts/9140DA
  • 4 weeks later...
