mantasrme Posted January 3, 2011 Share Posted January 3, 2011 (edited) As the title says i'm breaking a manta hatch, started life as a 1.8 but was converted to a cih (so none of those bits available ) I've just started striping it so will add to this list as i go along and check parts, If there's anything specific your after just ask and i'll check it for you Rear seat belt set complete £15 £10 SOLD Rear seats Black/charcol £5 Free to collect (Gone) SOLD Front seat belt (minus tunnel stalks as they're damaged) £5 outer B pillar trims (all pins intact) £10 pr SOLD 1/4 panel trims Grey £5 pr Dashboard top and lower parts £10 SOLD standard front calipers £5pr SOLD Front wiper motor and mech £5 SOLD Rear wiper £5 SOLD 1/4 glass brown tint (opening type) £5 pr Free to collect GT/e gearbox good £25 £15 SOLD Good GT/e engine complete with injection, ecu, loom, starter etc £50 Injection manifold with new fuel pipes £5 SOLD Injection wiring loom £2 Flywheel £3 Steering column complete with switches and steering wheel (no ign switch) £10 Doors inc glass and winder mech (no locks) good condition slight rust forming along lower inner lip £30 each (pics to follow) Fuse box and complete wiring loom £10 Large square washer bottle and bracket £3 SOLD Small/medium items can be posted large or fragile items collection only (like glass) All items are in Harrogate, N-yorkshire The reason i'm not repairing it is that a couple of years ago the owner put it back on the road from a long time stored. He had a lot of welding done at a local garage. However they didn't chop 1 single bit of rot out They just patched over all the rusty areas then filled over the repairs, no rust treatment either. So 2 years later the rust has broken through the thin metal they used for the patches, i've checked it over and ripped off a couple of the patches and its nasty To repair it now it needs welding to both rear sills (inner/middle and outer) both rear arches, lower rear corners, lower back panel, A-pillars, inner wing tops, jacking points, swan necks, chassis rails, washer bottle tray, battery tray, scuttle panel repair Oh its also rusting around the sunroof, then it would need fully painting and rebuilding. At the end of all that its a 1.8 hatch with a 2.0 Cih engine fitted so wouldn't be worth much However broken it can help many other manta's stay on the road so a fitting end rather than just getting crushed Edited January 16, 2011 by mantasrme Quote Link to comment Share on other sites More sharing options...
si-north Posted January 3, 2011 Share Posted January 3, 2011 (edited) Hi, my brothers after a rear axle, I may be able to convince him of the 5 spped box and prop too if the money's right but we're along way away, so we'd have to suss the price of a courior too... I'm after a lower steering columb uj if its not siezed! Can you help? Edited January 3, 2011 by si-north Quote Link to comment Share on other sites More sharing options...
benw456 Posted January 3, 2011 Share Posted January 3, 2011 Have you got a full lockset on one key? Ben Quote Link to comment Share on other sites More sharing options...
stevey Posted January 3, 2011 Share Posted January 3, 2011 hi, i'll have the front and rear wipers if you can post? and they work? regards steve Quote Link to comment Share on other sites More sharing options...
mantasrme Posted January 3, 2011 Author Share Posted January 3, 2011 Hi, my brothers after a rear axle, I may be able to convince him of the 5 spped box and prop too if the money's right but we're along way away, so we'd have to suss the price of a courior too... I'm after a lower steering columb uj if its not siezed! Can you help? Rear axle is already taken i'm affraid, i'll check the steering U/J when i take the front end apart later in the week Have you got a full lockset on one key? Ben Yep full lockset including fuel cap on one key (plus a spare) say £20 hi, i'll have the front and rear wipers if you can post? and they work? regards steve Yes both fully working, should be able to post will get the rear one taken out wednesday and work out postage Quote Link to comment Share on other sites More sharing options...
dog321fish Posted January 3, 2011 Share Posted January 3, 2011 Hi Are the calipers ATE or Delco? Quote Link to comment Share on other sites More sharing options...
yorkshirelad Posted January 3, 2011 Share Posted January 3, 2011 What year is it and is the sunroof seal any good? Quote Link to comment Share on other sites More sharing options...
mantasrme Posted January 4, 2011 Author Share Posted January 4, 2011 Hi Are the calipers ATE or Delco? Not sure will check What year is it and is the sunroof seal any good? Its a D reg and the sunroof seal doesn't look that good Pretty sure it was leaking which is why the roof i so rusty Quote Link to comment Share on other sites More sharing options...
benw456 Posted January 4, 2011 Share Posted January 4, 2011 (edited) Yeah mate ill take the lockset. Could you also supply the connecting rods etc for the doors and the tailgate? Mines been delocked so need the rods etc. How would you like me to pay? PM me if you like. Cheers, Ben Edited January 4, 2011 by benw456 Quote Link to comment Share on other sites More sharing options...
mantasrme Posted January 14, 2011 Author Share Posted January 14, 2011 Hi Are the calipers ATE or Delco? Can't remember how to tell them apart (been a long time since i had standard calipers on one of my mantas) They are the standard manta calipers with sliding pistons (or should that be seizing) Don't have a manufacturers stamp on but say made in france and look to have been re-con'd with new seals I'll get a pic tomorrow. Quote Link to comment Share on other sites More sharing options...
benw456 Posted January 14, 2011 Share Posted January 14, 2011 Lockset turned up yesterday. Many thanks, Ben Quote Link to comment Share on other sites More sharing options...
rutts Posted January 14, 2011 Share Posted January 14, 2011 i will have gearbox if possible. pm post code for your garage or house please i will come over tomorrow (sat)dinnertime ish if ok. Quote Link to comment Share on other sites More sharing options...
Exclusive Opel Posted January 14, 2011 Share Posted January 14, 2011 I'll take the B pillar trims if you still have them. Quote Link to comment Share on other sites More sharing options...
casper1483 Posted January 14, 2011 Share Posted January 14, 2011 Heyup mate I will have propshaft if it ant gone let me know how much i will come and fetch it Cheers.............................Casper. Quote Link to comment Share on other sites More sharing options...
mantasrme Posted January 14, 2011 Author Share Posted January 14, 2011 i will have gearbox if possible. pm post code for your garage or house please i will come over tomorrow (sat)dinnertime ish if ok. See you tomorrow I'll take the B pillar trims if you still have them. Yep still here, i'll check postage and PM you Heyup mate I will have propshaft if it ant gone let me know how much i will come and fetch it Cheers.............................Casper. Propshaft is still here (think i have a couple anyway) Say £5 Quote Link to comment Share on other sites More sharing options...
dog321fish Posted January 15, 2011 Share Posted January 15, 2011 (edited) ATE calipers have one piece + shaped spring retainer, Delco calipers have two long spring retainers if that helps you to identify them. I know they are heavy, but any idea of Post and packing cost please? Edited January 15, 2011 by dog321fish Quote Link to comment Share on other sites More sharing options...
casper1483 Posted January 15, 2011 Share Posted January 15, 2011 See you tomorrow Yep still here, i'll check postage and PM you Propshaft is still here (think i have a couple anyway) Say £5 Sweet i will pm you Quote Link to comment Share on other sites More sharing options...
rutts Posted January 15, 2011 Share Posted January 15, 2011 top guy, great new garage. thanks for the coffee Quote Link to comment Share on other sites More sharing options...
mantasrme Posted January 15, 2011 Author Share Posted January 15, 2011 ATE calipers have one piece + shaped spring retainer, Delco calipers have two long spring retainers if that helps you to identify them. I know they are heavy, but any idea of Post and packing cost please? Here's a quick pic from my phone of the caliper I use interparcel so can ship them to you for £8.50 (assuming i can find a strong box to put them in) Quote Link to comment Share on other sites More sharing options...
dog321fish Posted January 16, 2011 Share Posted January 16, 2011 Thanks for pic, PM sent. Cheers Dave Quote Link to comment Share on other sites More sharing options...
mantasrme Posted January 16, 2011 Author Share Posted January 16, 2011 top guy, great new garage. thanks for the coffee Always welcome mate Quote Link to comment Share on other sites More sharing options...
dog321fish Posted January 18, 2011 Share Posted January 18, 2011 Great calipers delivered today, are you sure you have covered your postage costs? If not what do I owe you? Thanks Quote Link to comment Share on other sites More sharing options...
mantasrme Posted January 18, 2011 Author Share Posted January 18, 2011 Great calipers delivered today, are you sure you have covered your postage costs? If not what do I owe you? Thanks Yep postage with interparcel is only £6.99 +vat (so £8.39 inc) thats why i use them Quote Link to comment Share on other sites More sharing options...
dog321fish Posted January 18, 2011 Share Posted January 18, 2011 Brilliant, Thanks again. Cheers Dave Quote Link to comment Share on other sites More sharing options...
Exclusive Opel Posted January 20, 2011 Share Posted January 20, 2011 Just to let you know your parcel arrived today. Quote Link to comment Share on other sites More sharing options...
