Manta/ascona B Poly Bushes & Kits With Club Discount
Retro Power
Full Polyurethane suspension bush to suit Opel Manta B, Ascona B and MK1 Vauxhall Cavalier.
We always use SuperPro bushes on our project vehicles as we've found them to be a superior fit to other manufacturers. A good example on this kit is the new metal shells which are supplied for the lower wishbones. Many kits don't include these and the bushes are sized to simply fit directly into the wishbone. This invariably leads to the bush spinning in the wishbone (rather than rotating on the inner tube as it should) causing rapid wear of the bush.
We can advise on fitting these bushes (or probably more relevant, removing the old bushes, as they can be temperamental little blighters!)
The only points of note on this kit are that on the chassis end of the Panhard rod you will need to retain the original inner tube, and for the anti-roll bar drop links you will need to retain all the original metal parts. If yours are corroded then OE links are still available from your motor factors: QH part number QLS1750S or Delphi part number TD272W.
All kits and bushes are in stock for next day delivery (included for FREE!)
Price is £290 Inc. VAT and Delivery (Next Day) which represents over 10% off RRP.
PAYPAL to paypal@retropower.co.uk
This is the contents of the kit which you will recieve (they will be in sealed packaging though!)
We can also supply any of the above 'sub-kits' individually.
We can supply the rear anti-roll bar to chassis (drop link) bushes (8 rubbers and 4 tubes) for an additional £50.
Finally we are currently sourcing Manta A lower arm bushes (all the others are the same as B) which we'll keep you posted on ;-)
  • 4 weeks later...
  • 2 months later...
  • 3 months later...
  • 3 weeks later...
  • 3 weeks later...
Thanks for ordering Matt.
As an update to the original post we have now worked with Superpro to bring out a new Panhard rod kit that includes the chassis tube (standard in our full kits now) and I can also supply the rear ARB drop link bushes as long as you have the ARB type that has a loop each end. This kit is £50 inc.VAT which is a lot, but then there are 8 top hat bushes and 4 tubes in the kit, so a lot of parts!
  • 1 month later...
  • 7 months later...
Hi Im new to the forum and I was looking for two sets of these bushing kits. Are these still available?
Ps.Sorry for digging up an old thread
Thanks in advance!
I also need to buy two sets of bushes. It would be good to know what you currently have on offer?
Thanks
  • 4 years later...
On 18/03/2019 at 15:10, Ajwatts80@googlemail.com said:
To whom it may concern
I'm after a full bush kit for the front and rear axels and the centre prop bust and I need every single bush, Can you email me a price for the lot please.
mantae703dho@gmail.com
Thank you
Adrian
Contact Retropower direct
