Alternative Tank For A Hatch
Leon
Has anyone used an alternative tank for a hatch? The originals as we know are poorly protected from the factory, and are difficult to find in good condition.
Anybody fitted anything different? I'm thinking a plastic tank from another car, an alloy custom tank or possibly even a plastic marine tank?
pretty sure Kev Abbot dabbled with the plastic tank off a calibra some while back , if i remember right it was a close match apart from a fouling one of the chassis members
I compared the tank off my calibra to the manta tank when I took if off to repair the fuel inlet/return lines. I think you'd really struggle to get it to fit.
Edited by Snowy
The calibra tank fitted. I had to remove the original floor. Chassis sections too.
It won't fit a standard car.
The tank is wide and high and the inlet for fuel meant I would of had to fabricate sections to cover that too
Exhaust was very close. Probably too close for comfort.
Anyway. It was binned in favor of an original tank but I don't think that is the answer.
Crappy manta stuff is old and rubbish.
I trip to the scrappers with a tape measure may be the future
Tank with a built in pump required also to avoid it rotting under the car.
or get in contact with alloy fabricators on ebay who make anything from ally.
take a tank get it copied with a hole fabricated for modern fuel pump fitment.
might corrode over time under the back but last better than an old new stock item.
What made me think of this was lifting a tank out of a 205 GTI I was dismantling, which has a lift pump in the tank. I think the idea of going round scrapyards with a tape measure is the best idea - actually mounting the tank is easy - it's the shape and the location of the filler neck that look to be the biggest potential headaches.
