What Do I Need To Convert 4 Speed To 5 Speed?
Daveyboy20
Hi Dave
You'll need the transmission, propshaft, rear cross member, cross member body mounts and the top of the tunnel oh and a speedo cable.
You can either cut the four speed tunnel out and fit the top section from the five speed or contact Paulmanta on here who can a conversion on the five speed shifter so it still comes out of the same hole.
Andy
Its a good weekends work if you are going to cut the tunnel top out and move the rear cross member mounts in the floor. Plenty of 5 speed cars being broken at the moment so getting all the parts you need shouldn't be much of a problem
Cheers
Andy
You can also get the converter from Thomas in germany
http://www.edelschmiede.com
I have done a 5 speed (not on a cavalier! but on an A series) and its easy. Shorten the linkage and the mounting plate and added an extender to the gearbox support and even got someone to graft the a series stick on so it looks like its a 4 speed.
You just need someone that's good at welding :-)
Andy
Thanks fellas - I'll leave it for now but keep on the lookout for bargain parts. Might try and do it around easter instead. I was kind of hoping new box and prop and a couple of hours work like on a capri!
It is only a couple of hours work. Even if you fit the five speed tunnel top it doesn't take very long at all.
I've done the conversion in the morning and drove the car in the afternoon.
