Retro Power Posted May 21, 2015 Share Posted May 21, 2015 Just canvassing for opinion here, any thoughts on pistons for a 2.4 16v ( frontera block cut down senator head ) What are the best options before going to full forged aftermarket items Quote Link to comment Share on other sites More sharing options...
rutts Posted May 21, 2015 Share Posted May 21, 2015 (edited) If you look on german ebay they advertise mercedes pistons for cih 16v. cheap price for standard pistons. Think i put opel cih in search Edited May 21, 2015 by rutts Quote Link to comment Share on other sites More sharing options...
H-400 Posted May 22, 2015 Share Posted May 22, 2015 (edited) http://www.ttautosport.be/?pagina=onderdelen&cat=11&detail=7 don't have expierence with this guy but just check out the web-site, grtz. (if you need some transelation...) Edited May 22, 2015 by H-400 Quote Link to comment Share on other sites More sharing options...
Retro Power Posted May 22, 2015 Author Share Posted May 22, 2015 Cheers folks, Andy - had a look at those on ebay.de, only confusion was the bore but I'm 99% sure that theyve got their listing wrong as KS only list a 96.5mm piston not a 97.5 (which would be pushing a CIH bore a bit far I'd think?) Will get my machine shop to find out if they can get the relevant KS part, pretty sure they can. H-400, it would be nice to put forged pistons in it but I'm pretty sure the budget won't stretch to it. Will check just in case! cheers Nat Quote Link to comment Share on other sites More sharing options...
Titson Posted June 10, 2015 Share Posted June 10, 2015 Mine were sourced from the States at about 500 for the set from memory, custom made. Quote Link to comment Share on other sites More sharing options...
Retro Power Posted August 17, 2015 Author Share Posted August 17, 2015 Right, well have got a set of the mercedes pistons that are touted as being the thing for the job and they don't look much good to me ! The comp height is taller (last thing you want on a big bore CIH!) and the gudgeon pin considerably bigger. I think Steve you are probably right!! Looks like custom forged ones! Could you tell me where you got yours from? Quote Link to comment Share on other sites More sharing options...
Retro Power Posted August 17, 2015 Author Share Posted August 17, 2015 Next question!......am I being stupid or can I use forged senator 24v pistons? Nobody used to list them but now I see that Wossner list them from stock, and up to 96.5mm bore........ Quote Link to comment Share on other sites More sharing options...
bigcliff Posted August 17, 2015 Share Posted August 17, 2015 You can but it will put your engine back to 2.0l instead of 2.4l which it was when Andy bilt it . Quote Link to comment Share on other sites More sharing options...
611 Posted August 18, 2015 Share Posted August 18, 2015 (edited) What about ENEM in sweeden, they list Woosner pistons for the 2.5 96mm and 97mm?http://enem.se/produkter.asp Edited August 18, 2015 by 611 Quote Link to comment Share on other sites More sharing options...
TJM Posted August 18, 2015 Share Posted August 18, 2015 Hello Guys I can supply CIH 2.4 Wossner Pistons in 96.00/96.50 or 97mm bore size, fill spec: Technical information is sourced from Wossner's latest catalogue Part Number K9006 Engine Type C2.4 NE OE Bore Size 95.00mm Bore Sizes Available 96.00mm - 2461.00cc 96.50mm - 2486.70cc 97.00mm - 2512.53cc Stroke 85mm Dome/Bowl Volume +3.77cc Wössner Comp. Ratio 12.0:1 OE Comp. Ratio 9.2:1 Comp. Height 31.5mm Valves Per Cylinder 2 Cylinders 4 PM or email me at sales(at)tjmotorsport.co.uk Regards Tim Quote Link to comment Share on other sites More sharing options...
Retro Power Posted October 12, 2015 Author Share Posted October 12, 2015 Little update, looking at exchange rates and various complications with existing engine parts, it's actually going to be cheaper to get a new engine built at Risse and sell the existing parts, so that's the new plan! Quote Link to comment Share on other sites More sharing options...
rutts Posted October 12, 2015 Share Posted October 12, 2015 Bloody hell that expensive. Sticking with eight valves then. Quote Link to comment Share on other sites More sharing options...
