wayne ingham Posted April 17, 2016 Share Posted April 17, 2016 Hi do the side trim clips fit in to a square hole ,if so what is size square on the clip.I can check in work to see if l got any of right size. Quote Link to comment Share on other sites More sharing options...
Snowy Posted April 21, 2016 Author Share Posted April 21, 2016 On 17/04/2016 at 10:15 PM, wayne ingham said: Hi do the side trim clips fit in to a square hole ,if so what is size square on the clip.I can check in work to see if l got any of right size. They do but someone has drilled the holes round and the clips I have are damaged. I will see if I can get a measurement. Thanks My lockset from Germany arrived today. Just in case it helps anyone out Kadett C locks fit the manta B. Much easier to find in Germany than the UK. So I have fitted the locks and the new door trim that arrived from ebay. Project images are available to Club Members Only, Click to become an OMOC Member. Project images are available to Club Members Only, Click to become an OMOC Member. One key now fits all. 1 Quote Link to comment Share on other sites More sharing options...
Snowy Posted April 22, 2016 Author Share Posted April 22, 2016 (edited) Transferred my card template to steel. Will hopefully be welding tomorrow. Edited August 18, 2017 by Snowy 2 Quote Link to comment Share on other sites More sharing options...
Snowy Posted April 23, 2016 Author Share Posted April 23, 2016 (edited) So I finished my washer bottle repair panel this morning then welded it in. One job done. Now to repair the a post and chassis rail. Edited August 18, 2017 by Snowy 2 Quote Link to comment Share on other sites More sharing options...
Snowy Posted April 24, 2016 Author Share Posted April 24, 2016 (edited) Drivers side floor repaired today. Not the best looking but all the rot was cut away. Just the a post now and then the chassis rail. Edited August 18, 2017 by Snowy 1 Quote Link to comment Share on other sites More sharing options...
Snowy Posted April 26, 2016 Author Share Posted April 26, 2016 (edited) All welded up. Sills and chassis rail now... Edited August 18, 2017 by Snowy 2 Quote Link to comment Share on other sites More sharing options...
Snowy Posted April 27, 2016 Author Share Posted April 27, 2016 (edited) Nipped up to Mantasrme today to get some wheels so when I got back decided to start looking at the drivers side chassis rail. The only way to repair this was to take the engine out. I've noticed a few people on here rave about dropping the subframe complete and pulling the lot out so I thought I would give this a go. Not for me I think. It's much easier to lift the engine and box out then just remove the subframe separately. I did loose all my balls from the lower steering column bearing though Does anyone know the size they should be? Edited August 18, 2017 by Snowy 1 Quote Link to comment Share on other sites More sharing options...
Snowy Posted April 28, 2016 Author Share Posted April 28, 2016 (edited) Look what I picked up today. 1800 engine complete with mounts sump etc, gearbox and prop. Not for this car. But at £375 an absolute bargain. Edited August 18, 2017 by Snowy 1 Quote Link to comment Share on other sites More sharing options...
Snowy Posted April 29, 2016 Author Share Posted April 29, 2016 (edited) Why do people patch over rust.... if your chassis rails look like this then look away as this will make you cry So start grinding and cutting.. This is what you're left with...I'm sure it wasn't this bad when it was patched. Edited August 18, 2017 by Snowy 2 Quote Link to comment Share on other sites More sharing options...
wayne ingham Posted April 29, 2016 Share Posted April 29, 2016 Very good work and doing it out in the open. just out of curiosity whoud you carry out work on someone else car. By the way don't need any repairers to my Manta. Quote Link to comment Share on other sites More sharing options...
Snowy Posted April 29, 2016 Author Share Posted April 29, 2016 55 minutes ago, wayne ingham said: Very good work and doing it out in the open. just out of curiosity whoud you carry out work on someone else car. By the way don't need any repairers to my Manta. I have welded other peoples car before yes, and yes I would again if asked. My work might not be up to the standard of others on here but all the rot is cut away and the repairs are strong and safe. But yes I was enjoying the rain earlier. The only thing that stopped me is I'm out of steel thick enough to repair the inner chassis leg. 3 Quote Link to comment Share on other sites More sharing options...
wayne ingham Posted April 29, 2016 Share Posted April 29, 2016 The standard of the welding is looking very good to me 1 Quote Link to comment Share on other sites More sharing options...
Snowy Posted April 30, 2016 Author Share Posted April 30, 2016 (edited) Starting to look like a chassis rail again... Edited August 18, 2017 by Snowy Quote Link to comment Share on other sites More sharing options...
Snowy Posted May 2, 2016 Author Share Posted May 2, 2016 (edited) Next portion of the inner rail made. Just got to wait for the rain to stop so I can weld it in. Edited August 18, 2017 by Snowy 1 Quote Link to comment Share on other sites More sharing options...
®evo03 Posted May 4, 2016 Share Posted May 4, 2016 Reminds me of your enlarged grill, Check out large grill opening, makes sense, SA Market. Its a Chevy Chevair, s,africa. Only available 4dr, cavalier, manta grill, b grill before facelift 3 Quote Link to comment Share on other sites More sharing options...
Snowy Posted May 8, 2016 Author Share Posted May 8, 2016 (edited) Well between showers I managed to weld in the front piece. But the other side that looked good was rotten also. so this had to come out. But all the rot has gone now, the inner is complete. Just the outer to finish now. Edited August 18, 2017 by Snowy 1 Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted May 10, 2016 Share Posted May 10, 2016 Nice work and doing it outside deserves a thumbs up too 1 Quote Link to comment Share on other sites More sharing options...
Snowy Posted May 14, 2016 Author Share Posted May 14, 2016 (edited) The drivers side chassis rail is now finished..... Not the nicest looking repair but no rot was left behind.. But just like any other manta holes always appear... Edited May 18, 2016 by Snowy 2 Quote Link to comment Share on other sites More sharing options...
TheRealExile Posted May 14, 2016 Share Posted May 14, 2016 Making good headway there better than me for sure.... entire budget has been wiped out by wrecking tenants they managed to destroy 25 year warranty laminate, the kitchen and all carpets oh and the stair rail so that's my next 3 weeks taken including a full re-decorate as all the nice white gloss is now a nice nicotine yellow shade need to sell it to fund buying the house I'm in and was hoping to have a bit over to lavish on the Manta! Quote Link to comment Share on other sites More sharing options...
