Rear disc brake kits
mantasrme
20 hours ago, Luisetegsi said:
Hi Chaps ,Very good piece of info
I´m just about figuring out how to fit the calipers if at the top of the hub or vertically in the bach using the manta Cable. I´ve got  a couple of questions
  1. When you said "You also need stops for the outer cable around the torque tube cross member area" What you mean exactly? Cannot the original ones designed for the manta cable used for this purpose?
  2. About the hydraulic conection.. does the rigid cooper pipe used for the standard brake actuators  reach the caliper inlet port?
Regards
Luis
On top is for the Manta cable. Behind the hub is for the Astra cable
1: no the stops need to be tube shaped for the ends of the astra cable to sit into, so they are held in place when the cable is slack
2: No you need to add a flexy brake hose to reach to the caliper as it moves
Unless you have an a series stoppers ready built in. 🤔
Good Morning
All right got it, A lot more clear now. Do you know  if the flexihose has to be made to order or can any commercial size be used? maybe the original ones from astra mk4?
regards
Good point forgot about that
22 hours ago, Luisetegsi said:
Good Morning
regards
You can use an original one from various cars, It needs a banjo fitting one end and a screw fitting the other to join the hard pipe. People have used the mk4 ones with this setup, you will need to make a bracket to secure the end that joins the hard metal brake pipe at the axle
  • 2 months later...
TRW do a full Astra G Rear caliper kit — 2 x calipers 2 x caliper carriers and a set of brake pads.
I don’t have the part number to hand but I have the kit in the box and I’ll check it out — it’s handy because you get the carriers included.
Cheers
  • Thanks 1
  • 2 months later...
I’m just getting around to doing this conversation now...
You say to use a brake hose with a banjo fitting — my Astra G callipers don’t use a banjo fitting. Am I missing something here?
That is for a banjo fitting, the OE vauxhall one is a square end like this https://www.ebay.co.uk/itm/193205844595https://www.ebay.co.uk/itm/193205844595
some people use this and make a bracket for the end to join the metal pipe at the axle tube. Some people use a custom braided hose made with a standard banjo end like this https://www.ebay.co.uk/itm/333468148078
  • Like 4
Thanks for that info — time to look for a banjo bolt!
Looking at the thread it looks like an M10 x 1.5 but that’s a guess — can anyone confirm that’s what the Astra G caliper thread is?
Yes its M10x1.5 from memory
You are correct — I tried an M10 x 1.5 bolt just to check.
I’m waiting to see if my local Opel dealer has any in stock — I gave him OE the part numbers but I haven’t heard back yet.
  • 2 months later...
  • 6 months later...
