ANDY ABBOTT Posted February 14, 2020 Share Posted February 14, 2020 If of interested to anyone I can contact the seller if your not on Facebook. 😣 Quote Link to comment Share on other sites More sharing options...
biffy1984 Posted February 14, 2020 Share Posted February 14, 2020 Proper bargain if those bearings are new. Quote Link to comment Share on other sites More sharing options...
ANDY ABBOTT Posted February 14, 2020 Author Share Posted February 14, 2020 54 minutes ago, biffy1984 said: Proper bargain if those bearings are new. It's all brand new apparently Quote Link to comment Share on other sites More sharing options...
Berlinetta Posted February 16, 2020 Share Posted February 16, 2020 Would these suit the rear axle of a 1978 1.9 automatic? I dont know if I actually need them or not at present... Quote Link to comment Share on other sites More sharing options...
ANDY ABBOTT Posted February 16, 2020 Author Share Posted February 16, 2020 2 hours ago, Berlinetta said: Would these suit the rear axle of a 1978 1.9 automatic? I dont know if I actually need them or not at present... I honestly couldn't tell you mate sorry, I'm not familiar with ratios etc.. 1 Quote Link to comment Share on other sites More sharing options...
KAA Posted February 16, 2020 Share Posted February 16, 2020 4 hours ago, Berlinetta said: Would these suit the rear axle of a 1978 1.9 automatic? I dont know if I actually need them or not at present... The 9:31 stamped on the crown wheel is the ratio - 31 divided by 9 = 3.44. 3.44 : 1 may not be the right ratio for the 1.9 auto if you want to keep it original (think it is probably 3.67 : 1 on your car). 1 1 Quote Link to comment Share on other sites More sharing options...
MrCarlos Posted February 18, 2020 Share Posted February 18, 2020 On 16/02/2020 at 22:51, KAA said: The 9:31 stamped on the crown wheel is the ratio - 31 divided by 9 = 3.44. 3.44 : 1 may not be the right ratio for the 1.9 auto if you want to keep it original (think it is probably 3.67 : 1 on your car). Yes a 3.44 would be wrong for a 1.9 auto I have a perfect condition used 3.67 cwp set with mint bearings at £100 plus postage 🙂  Quote Link to comment Share on other sites More sharing options...
malbasys Posted February 18, 2020 Share Posted February 18, 2020 3.44:1 gives a brilliant ratio for long distance cruising - my SA built 1900 A has a 3.44.. If you were to swap to this this though, you'd also need to swap the speedo or it would be under-reading. Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted February 18, 2020 Share Posted February 18, 2020 yes the 3.44 would lower the cruising revs and in most cases autos are usually fitted with a lower ratio final drive anyway. as mentioned the speedo would be out but you would just need a 'red' drive unit to swap for the 'yellow' unit in the gearbox to bring it back to correct Quote Link to comment Share on other sites More sharing options...
