Troubled Taff Posted July 31, 2021 Share Posted July 31, 2021 Not good! HC is unburnt fuel, the car has been standing a while, but starts and seems to drive ok. Any advice please? Timing, plugs, super unleaded, should I drop in some Redex and give it another go? Or the infamous AFM, should I take a screwdriver or allan key to that? Any direction would be gratefully accepted. THX. Anyone know someone with an old Crypton Tumer? Quote Link to comment Share on other sites More sharing options...
Troubled Taff Posted July 31, 2021 Author Share Posted July 31, 2021 One more but of info, I've had the engine out and replaced the the head and dump baskets and the front and rear crank seals. So, the engine has only done 120 miles since last MOT. Then the HC reading was 139, yes 139 ppm. Strange things are afoot here ! Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted July 31, 2021 Share Posted July 31, 2021 Does it need an Italian tune up? Quote Link to comment Share on other sites More sharing options...
Trooker Posted July 31, 2021 Share Posted July 31, 2021 I have a working spare AFM if you want to try that. Wonder if your injectors are slightly leaking or if the cold start one is playing up a bit. Are the plugs really sooted up? Quote Link to comment Share on other sites More sharing options...
Troubled Taff Posted July 31, 2021 Author Share Posted July 31, 2021 I'm going to try some Redex and a long drive. I'll take the plugs out and give them a clean, change the air filter and oil. As there was such a difference without the car being used it can't be much, the AFM must be ok if hasn't, been in use. I am suspecting it might be ignition timing, as the head was off that may be out but my old strobe light has it spot on. I hope to take it back next week and I was hoping someone has something difinative. Thanks for the offer of the AGM I appreciate that. Thanks but I'll try the other stuff and cross my fingers. Otherwise I'll be looking for a Crypton Tuner in Hampshire. Anyone know one? Quote Link to comment Share on other sites More sharing options...
Trooker Posted July 31, 2021 Share Posted July 31, 2021 If the car has been sitting, it’s not much hassle & might help so I’d be apt to go over the electrical connections & squirt a little contact cleaner in the blue temp plug & insert & disconnect a couple of times. Same with the AFM plug. There’s an Earth on the rear of the inlet manifold that may benefit from a rub with 240emery too. There’s also ye olde air-leaks possibly that can throw the injection out too. Easy-start seems to be a favourite to help detect those. Quote Link to comment Share on other sites More sharing options...
®evo03 Posted August 1, 2021 Share Posted August 1, 2021 Had this recently, but with a carb! Stuipidly it was petrol that was in the car for sometime, approx two yrs, emissions where of the scale on takeover, a bit of driving, and a refill or a few, and fixed, easy fix! Quote Link to comment Share on other sites More sharing options...
Trooker Posted August 1, 2021 Share Posted August 1, 2021 2 hours ago, ®evo03 said: Had this recently, but with a carb! Stuipidly it was petrol that was in the car for sometime, approx two yrs, emissions where of the scale on takeover, a bit of driving, and a refill or a few, and fixed, easy fix! That’s interesting, did it start ok & feel fairly normal to drive? Quote Link to comment Share on other sites More sharing options...
fullsunian Posted August 2, 2021 Share Posted August 2, 2021 With HC reading that high, I would guess it is something fairly obvious. Check for air leaks in the induction system especially if you have not long had the engine out. Left a vac pipe of somewhere possibly? Quote Link to comment Share on other sites More sharing options...
®evo03 Posted August 2, 2021 Share Posted August 2, 2021 Drive it for a while to use the juice up, before refilling, was running outta time to use, so went ahead with mot, thats when it went wrong, right outside mot door, turned a blind eye, so it passed, it did drive normal but wouldnt tick over, a fill of juice cured it ! Weird, think yours might be an air leak! Quote Link to comment Share on other sites More sharing options...
Troubled Taff Posted August 3, 2021 Author Share Posted August 3, 2021 Thanks all, I'll let them oh know what happens. I haven't had time to give Diane t a recent n but I have a bottle of Wynnes. It day 350mls to 20l of petrol and do 100 miles. I'll give that a go this week. Quote Link to comment Share on other sites More sharing options...
