mantacrazy22 Posted May 5, 2022 Share Posted May 5, 2022 Hi I have found a set of 17s et40 7j will they fit OK thanks matt 1 Quote Link to comment Share on other sites More sharing options...
Danny D114BCW Posted May 5, 2022 Share Posted May 5, 2022 Off set I don’t think will be right. Would be too tucked into the arch 1 Quote Link to comment Share on other sites More sharing options...
mantacrazy22 Posted May 5, 2022 Author Share Posted May 5, 2022 Thanks Danny had a feeling that would be the case Quote Link to comment Share on other sites More sharing options...
Moonmonkey Posted May 5, 2022 Share Posted May 5, 2022 As Danny says with a 40mm offset the wheel would be significantly inboard - 22.7mm closer to the strut compared to a standard 6x14. Ronal. Using 10mm wheel spacers will push the wheel out back to the equivalent of a 30mm offset, meaning it will only be 12.7mm closer to the suspension, but it will be 12.7mm closer to the edge of the wheel arch. Scrub radius will be similar to the standard wheel to Just depends if you want to use a spacer or not. Problem is that there are not too many wheel options for Mantas with a sensible offset these days. 1 Quote Link to comment Share on other sites More sharing options...
Danny D114BCW Posted May 5, 2022 Share Posted May 5, 2022 This site is great for giving you some idea https://www.willtheyfit.com/wheels/ 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted May 5, 2022 Share Posted May 5, 2022 (edited) All depends on width tbh, but I can speak for 17” and 7.5” on Front, 8” on rear. I had my alloy offset made at ET40 as no one had a definite answer when I was making enquiries what actually worked. My tyre widths are 215 Front and 235 rear, @ 40 profile. Front as in pic 1 is ET34 (6mm spacer) 7.5x17 with 215/40R17 tyres Front as in pic 2&3 is ET32 (8mm spacer) 8x17 with 235/40R17 tyres Pic4 car out on ground is sat with the above. However, I have removed the spacers on rear, so that it’s ET40 as a test for a mate on FB and it works! clearance is tighter, but no worse than front to shocks. After all, clearance us clearance as they say. I don’t have a pic on hand. so if I was to reorder the wheels now, I would order fronts and rears at ET35. Funnily enough this is exactly what I originally was going to go with, but when ordering I went 100% caution as I had not been there was no definite answer with clearance pictures. This is a site I use for different calculators btw https://www.tyresizecalculator.com/tyre-wheel-calculators/wheel-offset-backspace-calculator Edited May 5, 2022 by Jessopia74 1 Quote Link to comment Share on other sites More sharing options...
Moonmonkey Posted May 5, 2022 Share Posted May 5, 2022 There is also this website https://www.wheel-size.com/calc/?wheel1=195-60-14X6ET30&wheel2=225-35-17X7.5ET30&fcl=50mm&wcl=30mm&scl=50mm&sr=0mm I’ve just ordered a set of Speedline Marmora’s 17x7.5 ET35. I have also got some 5mm spacers so I can be at ET30 Quote Link to comment Share on other sites More sharing options...
mantacrazy22 Posted May 6, 2022 Author Share Posted May 6, 2022 Much appreciated guys that clears it up for me I may have a punt on them and go down the spacer route Quote Link to comment Share on other sites More sharing options...
mantacrazy22 Posted May 6, 2022 Author Share Posted May 6, 2022 6 hours ago, Jessopia74 said: All depends on width tbh, but I can speak for 17” and 7.5” on Front, 8” on rear. I had my alloy offset made at ET40 as no one had a definite answer when I was making enquiries what actually worked. My tyre widths are 215 Front and 235 rear, @ 40 profile. Front as in pic 1 is ET34 (6mm spacer) 7.5x17 with 215/40R17 tyres Front as in pic 2&3 is ET32 (8mm spacer) 8x17 with 235/40R17 tyres Pic4 car out on ground is sat with the above. However, I have removed the spacers on rear, so that it’s ET40 as a test for a mate on FB and it works! clearance is tighter, but no worse than front to shocks. After all, clearance us clearance as they say. I don’t have a pic on hand. so if I was to reorder the wheels now, I would order fronts and rears at ET35. Funnily enough this is exactly what I originally was going to go with, but when ordering I went 100% caution as I had not been there was no definite answer with clearance pictures. This is a site I use for different calculators btw https://www.tyresizecalculator.com/tyre-wheel-calculators/wheel-offset-backspace-calculator Hi jess did you use longer studs with your spacers 1 Quote Link to comment Share on other sites More sharing options...
Moonmonkey Posted May 6, 2022 Share Posted May 6, 2022 Hi Matt Yes you will need longer studs. Some of the spacers kits come with longer studs. I’m using H&R spacers which come with 10mm longer studs for the 5mm spacers. It’s a bit of a pain to change the studs but I was upgrading the whole front suspension, and brakes (why I need the 17inch rims) so I already had everything in pieces 1 Quote Link to comment Share on other sites More sharing options...
mantacrazy22 Posted May 6, 2022 Author Share Posted May 6, 2022 1 hour ago, Moonmonkey said: Hi Matt Yes you will need longer studs. Some of the spacers kits come with longer studs. I’m using H&R spacers which come with 10mm longer studs for the 5mm spacers. It’s a bit of a pain to change the studs but I was upgrading the whole front suspension, and brakes (why I need the 17inch rims) so I already had everything in pieces Thanks mate where did you get yours Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted May 6, 2022 Share Posted May 6, 2022 Yes all wheels studs was replaced when I refurbished the suspension, simple knock them out with a big copper hammer. They are the same as fitted to mk2 escorts got mine from Burtons Quote Link to comment Share on other sites More sharing options...
Moonmonkey Posted May 6, 2022 Share Posted May 6, 2022 I got the spacers off ebay I think the seller was tunershop-worldwide, which is in Germany. When I’ve checked they were actually cheaper at dcperformance.co.uk. I think there are a lot of places selling H&R spacers but there are other brands to, but not all come with the longer studs. With 10mm spacers you may be better having ones with the built in spigot rings. The thinner spacers don’t need them as the hub spigot is long enough, but as you go thicker I think its better to have the ones with built in spigots to locate the wheel. 1 Quote Link to comment Share on other sites More sharing options...
mantacrazy22 Posted May 6, 2022 Author Share Posted May 6, 2022 Cheers guys atleast I know they will fit with spacers really like the wheels I've found so that's a big help Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted May 6, 2022 Share Posted May 6, 2022 5 minutes ago, mantacrazy22 said: Cheers guys atleast I know they will fit with spacers really like the wheels I've found so that's a big help Indeed mate, 5mm should be fine. Depending on tyres you could go out a bit more 1 Quote Link to comment Share on other sites More sharing options...
mantacrazy22 Posted May 6, 2022 Author Share Posted May 6, 2022 Bought and collected them 😁will be trying on for size tomorrow see what I need spacer wise appreciate your advice guys sure I'll be back with more questions 1 Quote Link to comment Share on other sites More sharing options...
611 Posted May 6, 2022 Share Posted May 6, 2022 1 hour ago, mantacrazy22 said: Bought and collected them 😁will be trying on for size tomorrow see what I need spacer wise appreciate your advice guys sure I'll be back with more questions Got my studs from these guys http://www.speedshack.co.uk/ gave them a call, the guy was super helpful. Andy 1 Quote Link to comment Share on other sites More sharing options...
mantacrazy22 Posted May 7, 2022 Author Share Posted May 7, 2022 7 hours ago, 611 said: Got my studs from these guys http://www.speedshack.co.uk/ gave them a call, the guy was super helpful. Andy Super will have a look thanks Quote Link to comment Share on other sites More sharing options...
mantacrazy22 Posted May 7, 2022 Author Share Posted May 7, 2022 Bit of an update tried them on today but think I've made a bit of a mistake I ordered 5mm h&r spacers all round but I'm thinking I may be of gone for bigger oh well see what they are like on,hopefully get some time soon to refurb the wheels and do them gloss black 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted May 7, 2022 Share Posted May 7, 2022 Yeah, that’s issue with the width, I only have experience with the 8” on rear and a much bigger tyre. But those are narrow/very low . 205/40 ? Quote Link to comment Share on other sites More sharing options...
mantacrazy22 Posted May 8, 2022 Author Share Posted May 8, 2022 Yeh 205 40s need to think about tyres once I've got them fitted properly bear in mind I never moved car for them to settle a little what's your thoughts on tyre size for them 1 Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted May 8, 2022 Share Posted May 8, 2022 Be careful spacing out too far, you may need longer studs. I used mk2 escort studs when I converted to rear disks. 1 1 Quote Link to comment Share on other sites More sharing options...
Moonmonkey Posted May 8, 2022 Share Posted May 8, 2022 (edited) 7 hours ago, mantacrazy22 said: Yeh 205 40s need to think about tyres once I've got them fitted properly bear in mind I never moved car for them to settle a little what's your thoughts on tyre size for them I’ve gone for 7.5J rims so I’ve been thinking 225/35x17 as it is the same diameter as the standard, but there is only really Yokohama who make a tyre in that size. I think that might be a little wide for a 7J rim, and the 35 profile might be a bit harsh as well. The other option is 215/40x17 which should fit on a 7J but they are 14mm larger in diameter so the speedometer will under read by about 2%, so the speedometer will show 29.3mph when you are actually doing 30mph. The good thing about 215/40x17 is that it’s a common tyre made by lots of manufacturers. I’m going to dummy fit the bare rims and measure up before deciding on tyres. Edited May 8, 2022 by Moonmonkey 1 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted May 8, 2022 Share Posted May 8, 2022 2 hours ago, Moonmonkey said: I’ve gone for 7.5J rims so I’ve been thinking 225/35x17 as it is the same diameter as the standard, but there is only really Yokohama who make a tyre in that size. I think that might be a little wide for a 7J rim, and the 35 profile might be a bit harsh as well. The other option is 215/40x17 which should fit on a 7J but they are 14mm larger in diameter so the speedometer will under read by about 2%, so the speedometer will show 29.3mph when you are actually doing 30mph. The good thing about 215/40x17 is that it’s a common tyre made by lots of manufacturers. I’m going to dummy fit the bare rims and measure up before deciding on tyres. See my pics above I use 215/40 front on a 7.5” rim. 2 hours ago, Moonmonkey said: I’ve gone for 7.5J rims so I’ve been thinking 225/35x17 as it is the same diameter as the standard, but there is only really Yokohama who make a tyre in that size. I think that might be a little wide for a 7J rim, and the 35 profile might be a bit harsh as well. The other option is 215/40x17 which should fit on a 7J but they are 14mm larger in diameter so the speedometer will under read by about 2%, so the speedometer will show 29.3mph when you are actually doing 30mph. The good thing about 215/40x17 is that it’s a common tyre made by lots of manufacturers. I’m going to dummy fit the bare rims and measure up before deciding on tyres. The std rolling radius is too small imo for the arches. They need a 1” bigger wheel that will also raise car slightly for those bloody speed bumps. Also Janta likes a bit of Rake, so slightly bigger rear mate car sit right, also imho. I did originally go with 215/40 all round as the 225 option was not viable due to availability/price as it’s a pretty rare size. And that did not look too bad tbh. 2 1 Quote Link to comment Share on other sites More sharing options...
Moonmonkey Posted May 28, 2022 Share Posted May 28, 2022 (edited) Finally finished the front suspension, brakes and wheels. I’ve gone for Speedline Mamora SL2 17x7.5 ET35, with a 5mm spacer and 215/40x17 Pilot Sport 4’s Good clearance all round on the front suspension, could go a bit wider but tyre getting close to shock absorber when suspension is unloaded. Plenty of room under load though. Edited May 28, 2022 by Moonmonkey 6 Quote Link to comment Share on other sites More sharing options...
