®evo03 Posted August 25, 2022 Share Posted August 25, 2022 6x wheels, came off narrow body 400. £70 each Ideal for widening project. Also 2x front brake discs, 400 spec. New never fitted. £100 Northern Ireland, courier or pallet would need organised, last pallet UK to NI was approx £90, last year. Three centre cabs, free with wheels. Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted August 25, 2022 Share Posted August 25, 2022 Got any details on the discs? Do they fit the 5stud hub? Quote Link to comment Share on other sites More sharing options...
®evo03 Posted August 25, 2022 Author Share Posted August 25, 2022 Can grab pics tomorrow. But I'm guessing they fit the 5 studs hub. Ordered for a 400. 1 Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted August 26, 2022 Share Posted August 26, 2022 Pm sent, I’ll take all 6 1 Quote Link to comment Share on other sites More sharing options...
®evo03 Posted August 26, 2022 Author Share Posted August 26, 2022 Disc photos. New never fitted. Dry stored. Slight surface flash. Will clean with wire wool. Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted August 26, 2022 Share Posted August 26, 2022 I will see if I can the info on the hub they fit, as the centre seems larger than `I expected for the hub. Think mine are GS/e Quote Link to comment Share on other sites More sharing options...
®evo03 Posted August 27, 2022 Author Share Posted August 27, 2022 They have GM stamped on them. They are standard 400 front vented discs. Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted August 29, 2022 Share Posted August 29, 2022 On 27/08/2022 at 07:27, ®evo03 said: They have GM stamped on them. They are standard 400 front vented discs. Found the info, they look to be larger mounting that the Commodores hubs. Quote Link to comment Share on other sites More sharing options...
GTEPETE Posted August 29, 2022 Share Posted August 29, 2022 Look like Monza discs (unless they are same p/n) maybe Herman can confirm? Quote Link to comment Share on other sites More sharing options...
H-400 Posted August 30, 2022 Share Posted August 30, 2022 400 discs have the partnr. 90121933, they are the same as Commo and the first generation Monza/Senator without ABS. Inside dia. 88mm and the later Monza/Senator are bigger. Something as 94mm. Outside dia of 400 and Commo are 271, as also the old gen. Monza Quote Link to comment Share on other sites More sharing options...
®evo03 Posted August 30, 2022 Author Share Posted August 30, 2022 Wheels......gone. Disks where ordered for a 400, so should be that. says GM on them. That's it. Quote Link to comment Share on other sites More sharing options...
Wheelybin22 Posted September 24, 2022 Share Posted September 24, 2022 Good evening, can I ask is the discs still available? Thank you Quote Link to comment Share on other sites More sharing options...
®evo03 Posted September 25, 2022 Author Share Posted September 25, 2022 Yes, still available. Quote Link to comment Share on other sites More sharing options...
Wheelybin22 Posted September 26, 2022 Share Posted September 26, 2022 Pm sent Quote Link to comment Share on other sites More sharing options...
