Malcolm Cliff Posted September 7, 2022 Share Posted September 7, 2022 I noticed a leak of fluid on my brake valve,it has damaged the paint,where can I get a new one ? Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted September 7, 2022 Share Posted September 7, 2022 if its the 4 pipe original type fitted to most cars78- pre 83 ish they are prone to leaking. best bet is to replace with the later type vertical cylindrical unit. some pipework may need changing or re bending but they generally never leak. Quote Link to comment Share on other sites More sharing options...
Malcolm Cliff Posted September 7, 2022 Author Share Posted September 7, 2022 Where could I buy one of the later ones ? Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted September 8, 2022 Share Posted September 8, 2022 no doubt someone on here will have one for you .otherwise il have a look on ebay and see if i can see anything. Quote Link to comment Share on other sites More sharing options...
MrCarlos Posted September 10, 2022 Share Posted September 10, 2022 I have the later type available, good used condition. £30 plus postage and packing Quote Link to comment Share on other sites More sharing options...
Michael mcinerney Posted September 10, 2022 Share Posted September 10, 2022 2 hours ago, MrCarlos said: I have the later type available, good used condition. £30 plus postage and packing Hi Mr Carlos Do you have any more of them as I see mine is starting to weep.79 vauxhall Cavalier mk1 four pipes going to it. What would it be posted to Ireland if possible? Thank you Quote Link to comment Share on other sites More sharing options...
MrCarlos Posted September 11, 2022 Share Posted September 11, 2022 On 10/09/2022 at 18:03, Michael mcinerney said: Hi Mr Carlos Do you have any more of them as I see mine is starting to weep.79 vauxhall Cavalier mk1 four pipes going to it. What would it be posted to Ireland if possible? Thank you Yes i have a few of them 🙂 Quote Link to comment Share on other sites More sharing options...
Malcolm Cliff Posted September 16, 2022 Author Share Posted September 16, 2022 I have bought a Mini one,just need to know which pipe goes where! Quote Link to comment Share on other sites More sharing options...
GTEPETE Posted September 16, 2022 Share Posted September 16, 2022 2 hours ago, Malcolm Cliff said: I have bought a Mini one,just need to know which pipe goes where! Any photographs? Quote Link to comment Share on other sites More sharing options...
Malcolm Cliff Posted September 16, 2022 Author Share Posted September 16, 2022 Pic of original one and Mini one. Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted September 16, 2022 Share Posted September 16, 2022 will a mini one work ok. the manta one has the correct rear loading bias and is correct for the car ? Quote Link to comment Share on other sites More sharing options...
Malcolm Cliff Posted September 17, 2022 Author Share Posted September 17, 2022 Was to,d by people on here that a Mini one will work. Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted September 18, 2022 Share Posted September 18, 2022 thats ok then. wouldnt know that myself and personally would rather fit one that was designed for the car but i guess if the ratings are correct then it will work ok. Quote Link to comment Share on other sites More sharing options...
Malcolm Cliff Posted November 5, 2022 Author Share Posted November 5, 2022 My pal fitted the Mini brake valve recently,had to move the brakes pipes a little bit and fitted new nuts on the end of two of the pipes,works well,no leaks,all good. Before and after pics of brake valve. 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted November 5, 2022 Share Posted November 5, 2022 Should be very similar. Lots of cars of that age was fitted with a biased valve, some are adjustable too. Quote Link to comment Share on other sites More sharing options...
IanG Posted November 7, 2022 Share Posted November 7, 2022 On 10/09/2022 at 15:25, MrCarlos said: I have the later type available, good used condition. £30 plus postage and packing My 76 Cav has the twin pipe one, do you have any of them, it isn’t leaking but is very rusty! Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted November 9, 2022 Share Posted November 9, 2022 that early type rarely leak but are getting harder to find. someone may have one (or just wirewheel,sand,sandblast etc the one you have maybee ? OR possibly convert to the later manta 4 pipe type if you ever change brake pipes . Quote Link to comment Share on other sites More sharing options...
MrCarlos Posted November 9, 2022 Share Posted November 9, 2022 On 07/11/2022 at 16:20, IanG said: My 76 Cav has the twin pipe one, do you have any of them, it isn’t leaking but is very rusty! Should have one ian, will check tomorrow for you 🙂 1 Quote Link to comment Share on other sites More sharing options...
MrCarlos Posted November 10, 2022 Share Posted November 10, 2022 Got a good 2 pipe early type here Its £40 plus postage and packing 🙂 Quote Link to comment Share on other sites More sharing options...
IanG Posted November 10, 2022 Share Posted November 10, 2022 Great thanks can you pm me the total and how to pay and I will send some dosh 💰 Quote Link to comment Share on other sites More sharing options...
MrCarlos Posted November 10, 2022 Share Posted November 10, 2022 1 hour ago, IanG said: Great thanks can you pm me the total and how to pay and I will send some dosh 💰 Just pm'd you now 🙂 Quote Link to comment Share on other sites More sharing options...
seanpren Posted December 28, 2022 Share Posted December 28, 2022 Gents Has anyone a pic or diagram of the pipes for vertical cylindrical type? Dismantled mine almost 10 years ago and lost most documents I had for stripping and rebuilding 😕 Looks like Bottom outlet to passenger wheel Top outlet to master cylinder 2nd from top possibly to master cylinder 3rd from top is still attached and has a banjo fitted so possibly master cylinder too as doesn't appear long enough to cross the bay and reach the wheel anyways Quote Link to comment Share on other sites More sharing options...
Mike. Posted December 28, 2022 Share Posted December 28, 2022 Hope this helps you 👍 2 1 Quote Link to comment Share on other sites More sharing options...
seanpren Posted December 28, 2022 Share Posted December 28, 2022 Fantastic Mike thanks a million Could I trouble you for a pic of master cylinder whenever you get a chance? Quote Link to comment Share on other sites More sharing options...
Mike. Posted December 28, 2022 Share Posted December 28, 2022 the brake line nearest servo is the bottom pipe running past the bulkhead, the brake line fitted into the brass fitting at the front of the master cylinder is the top brake line running past bulkhead. Drivers front brake line is from bottom of master cylinder. 1 2 Quote Link to comment Share on other sites More sharing options...
