Diego LR Posted July 31, 2023 Share Posted July 31, 2023 Hi All Is the Opel Manta A dashboard supposed to be illuminated? If so, how do I replace the bulbs? My dashboard is pitch black at night and I am trying to understand if there are lights/bulbs somewhere that need replacing. Thank you 1 Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted July 31, 2023 Share Posted July 31, 2023 There will be bulbs somewhere. I don’t know where they are on the A series but if you find them, replace them with SMD replacement bulbs 1 Quote Link to comment Share on other sites More sharing options...
1900SR Posted July 31, 2023 Share Posted July 31, 2023 The dash lights can be turned off by rotating the light switch, so make sure that's not the problem first. 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted July 31, 2023 Share Posted July 31, 2023 They are like stage lights as such, and shine from the back (closest to driver) top edge of dash cover. They can be removed easy enough. Quote Link to comment Share on other sites More sharing options...
1200bandit Posted July 31, 2023 Share Posted July 31, 2023 (edited) 14 hours ago, Diego LR said: Hi All Is the Opel Manta A dashboard supposed to be illuminated? If so, how do I replace the bulbs? My dashboard is pitch black at night and I am trying to understand if there are lights/bulbs somewhere that need replacing. Thank you Got some LED bulbs from eBay,removed the plastic strip from the dash lights just seen yours is a A Manta mines a 1988 Should get some LED bulbs Edited July 31, 2023 by 1200bandit Quote Link to comment Share on other sites More sharing options...
611 Posted August 1, 2023 Share Posted August 1, 2023 On 31/07/2023 at 07:46, Diego LR said: Hi All Is the Opel Manta A dashboard supposed to be illuminated? If so, how do I replace the bulbs? My dashboard is pitch black at night and I am trying to understand if there are lights/bulbs somewhere that need replacing. Thank you I have a spare dash if you want me to take a pic? they push in from the back and there are about 6 i think from memory. But as @1900sr said check the main light switch to check that is working as the bulbs are a bit of a pain to change behind the dash with it in unless you take it out but that means speedo cable off etc.. 23 hours ago, 1200bandit said: Got some LED bulbs from eBay,removed the plastic strip from the dash lights just seen yours is a A Manta mines a 1988 Should get some LED bulbs A series light from behind so it never looks quite as good as yours even with LED's!! 1 Quote Link to comment Share on other sites More sharing options...
Diego LR Posted August 1, 2023 Author Share Posted August 1, 2023 On 31/07/2023 at 20:15, 1900SR said: The dash lights can be turned off by rotating the light switch, so make sure that's not the problem first. That was it. I rotated clock wise and the dash lights went on! Thank you 56 minutes ago, 611 said: I have a spare dash if you want me to take a pic? they push in from the back and there are about 6 i think from memory. But as @1900sr said check the main light switch to check that is working as the bulbs are a bit of a pain to change behind the dash with it in unless you take it out but that means speedo cable off etc.. A series light from behind so it never looks quite as good as yours even with LED's!! I fixed it following 1900sr advice. Do you happen to have a left side mirror and one of these in the link too?? https://www.ebay.de/itm/134110506993?epid=557835201&hash=item1f399beff1:g:bUUAAOSwAS5dC7pv 3 Quote Link to comment Share on other sites More sharing options...
611 Posted August 1, 2023 Share Posted August 1, 2023 42 minutes ago, Diego LR said: That was it. I rotated clock wise and the dash lights went on! Thank you I fixed it following 1900sr advice. Do you happen to have a left side mirror and one of these in the link too?? https://www.ebay.de/itm/134110506993?epid=557835201&hash=item1f399beff1:g:bUUAAOSwAS5dC7pv I have 2 mirrors, one is good one needs fixing. I will check what i have. When you say left do you mean UK passenger side? Yes i have the heater housing, its slightly modified as i had a fan fitted (see link) but when i swapped to injection i didn't need it so took it out and put in another i had. https://www.theopelproject.com/time-for-a-tidy-up-of-the-wiring/ again i can get pics if you are interested? Quote Link to comment Share on other sites More sharing options...
Diego LR Posted August 2, 2023 Author Share Posted August 2, 2023 16 hours ago, 611 said: I have 2 mirrors, one is good one needs fixing. I will check what i have. When you say left do you mean UK passenger side? Yes i have the heater housing, its slightly modified as i had a fan fitted (see link) but when i swapped to injection i didn't need it so took it out and put in another i had. https://www.theopelproject.com/time-for-a-tidy-up-of-the-wiring/ again i can get pics if you are interested? UK passenger side correct. For the heater housing yes pls send me some pics. Lmk if you need my email address for that Thank you Quote Link to comment Share on other sites More sharing options...
611 Posted August 2, 2023 Share Posted August 2, 2023 5 hours ago, Diego LR said: UK passenger side correct. For the heater housing yes pls send me some pics. Lmk if you need my email address for that Thank you I will take some pics and post them tomorrow. Andy Quote Link to comment Share on other sites More sharing options...
Diego LR Posted August 3, 2023 Author Share Posted August 3, 2023 23 hours ago, 611 said: I will take some pics and post them tomorrow. Andy Thanks - looking forward to it Quote Link to comment Share on other sites More sharing options...
611 Posted August 3, 2023 Share Posted August 3, 2023 Ok, mirrors. As you can see i have a matching pair. The are both in good condition but as you can see from the second pic the right (UK drivers) one the bracket is lose and the mirror wont stay in place. but the left side is fine. Here is a link with the full size images https://www.theopelproject.com/heater-housing/ as you can see i added a partition and fan to the left, this was so i could vent under bonnet heat up through the bonnet vent without any engine fumes getting into the heater vent. Its in good condition with all the locating holes in place and nothing broken. The light housing is intact and i think i even have a switch somewhere! I only removed it from mine as now i run injection instead of twin cards so don't get the same kind of heat in the engine bay now so decided to swap it for another one i had. Andy Quote Link to comment Share on other sites More sharing options...
Diego LR Posted August 5, 2023 Author Share Posted August 5, 2023 Hi Andy, I notice these mirrors' shape is rectangular. The one I have is round. Which one is the original shape of the Manta A? Re the heater housing, is it in the UK currently? Do you also have the rubber which wraps it around? Thank you Quote Link to comment Share on other sites More sharing options...
611 Posted August 5, 2023 Share Posted August 5, 2023 Most seem to have the rectangular mirrors in the sales brochures but some do have the round. Yes the heater housing is in the UK and no i dont have the rubber strip, the stuff i had went hard and then the bonnet never seals properly so when i changed the heater housing i got some new stuff from Dr Manta. Its just like the original but the bonnet seals properly now 🙂 You can see it here where im fitting the new stuff. https://www.theopelproject.com/lockdown-3-snagging-list/ and from Dr Manta http://dr-manta-shop.de/epages/0859c4be-b99b-4b88-8216-6a78b07dc4b5.sf/de_DE/?ObjectID=5737343 Quote Link to comment Share on other sites More sharing options...
Diego LR Posted August 7, 2023 Author Share Posted August 7, 2023 On 05/08/2023 at 22:53, 611 said: Most seem to have the rectangular mirrors in the sales brochures but some do have the round. Yes the heater housing is in the UK and no i dont have the rubber strip, the stuff i had went hard and then the bonnet never seals properly so when i changed the heater housing i got some new stuff from Dr Manta. Its just like the original but the bonnet seals properly now 🙂 You can see it here where im fitting the new stuff. https://www.theopelproject.com/lockdown-3-snagging-list/ and from Dr Manta http://dr-manta-shop.de/epages/0859c4be-b99b-4b88-8216-6a78b07dc4b5.sf/de_DE/?ObjectID=5737343 The white manta with the red livery is simply out of this world!!! Andy - what is the best way to contact you directly so we can move this conversation offline? Thank you Quote Link to comment Share on other sites More sharing options...
611 Posted August 7, 2023 Share Posted August 7, 2023 1 hour ago, Diego LR said: The white manta with the red livery is simply out of this world!!! Andy - what is the best way to contact you directly so we can move this conversation offline? Thank you That one is nice. Drop me a message via the forum and then i can send you my email address. Andy Quote Link to comment Share on other sites More sharing options...
