Mike. Posted December 10, 2023 Share Posted December 10, 2023 Sorry Wayne, keep hold of it, maybe someone else can make use of it 👍 2 Link to comment Share on other sites More sharing options...
®evo03 Posted December 10, 2023 Share Posted December 10, 2023 Are they different sizes? Thought they would be all the same? I have two, somewhere, can check over the Holidays if stuck. 1 Link to comment Share on other sites More sharing options...
1200bandit Posted December 10, 2023 Author Share Posted December 10, 2023 6 hours ago, Mike. said: Sorry Wayne, keep hold of it, maybe someone else can make use of it 👍 No need to apologise just happy that someone tried to help me out. If anyone in need of some headliner happy to post out. 1 Link to comment Share on other sites More sharing options...
mepbowles Posted January 3 Share Posted January 3 If you ever want to iron something heat sensitive, a good trick is to put something else between the iron and the item. A tea towel works really well and if it's very heat sensitive go low temp and go slow or use two tea towels. Link to comment Share on other sites More sharing options...
®evo03 Posted January 3 Share Posted January 3 Wayne, do you need the headline section for the sunroof? 1 Link to comment Share on other sites More sharing options...
TheRealExile Posted January 4 Share Posted January 4 13 hours ago, mepbowles said: If you ever want to iron something heat sensitive, a good trick is to put something else between the iron and the item. A tea towel works really well and if it's very heat sensitive go low temp and go slow or use two tea towels. I tried that with one of those new style plastic fivers, it didn't end well 🤣 but yeah in general it works just fine if you are not ham fisted like me 😁 1 Link to comment Share on other sites More sharing options...
1200bandit Posted January 5 Author Share Posted January 5 (edited) On 10/12/2023 at 20:37, ®evo03 said: Are they different sizes? Thought they would be all the same? I have two, somewhere, can check over the Holidays if stuck. Yes need 28x28 inches or more,do you still require the manifold to front pipe gasket,PM your address and post out to you Edited January 5 by 1200bandit Link to comment Share on other sites More sharing options...
®evo03 Posted January 6 Share Posted January 6 (edited) Wayne wouldn't have that size, just the sunroof panel head cloth size, can't imagine or understand what you need this size for, is it to the rear of sunroof? Try searching headlining or roof cloth. On here, thing there is a UK company making them Edited January 6 by ®evo03 Link to comment Share on other sites More sharing options...
1200bandit Posted January 10 Author Share Posted January 10 (edited) The lining is for the sun roof need to make it look better? Have removed the exhaust manifold,drilled out the sapped bolt Give a quick clean,the gasket does not line up also the bolts are very tight on the gasket Has anyone had a manifold to front pipe gasket of eBay Has been corrected? Edited January 10 by 1200bandit Link to comment Share on other sites More sharing options...
®evo03 Posted January 10 Share Posted January 10 No difference flipping the gasket? Is it a factory fitted manta sunroof, I have a roof cloth section here from an exclusive manta, if it is what you need? Link to comment Share on other sites More sharing options...
1200bandit Posted January 10 Author Share Posted January 10 Have tried the gasket every way will not fit ( did get the gasket from Terry which is much appreciate) Had a look on eBay,looking at the photos didn’t look right ( maybe just the photo) Just didn’t want the incorrect gasket Link to comment Share on other sites More sharing options...
1200bandit Posted January 16 Author Share Posted January 16 On 10/12/2023 at 20:37, ®evo03 said: Are they different sizes? Thought they would be all the same? I have two, somewhere, can check over the Holidays if stuck. Have you got the gasket yet Link to comment Share on other sites More sharing options...
®evo03 Posted January 16 Share Posted January 16 Yes Wayne, just arrived, surprised as the weather was quite bad. Thanks, I will be in the garage later tonight for an hour, will let you know. Then a wee whiskey, to beat the cold 🥶😎😂 Thanks again, owe you one, cheers lad. Link to comment Share on other sites More sharing options...
1200bandit Posted January 16 Author Share Posted January 16 No worries been seating in the garage for 6/7 years Link to comment Share on other sites More sharing options...
