Andrew Talbot-Scobie Posted June 9 Share Posted June 9 Hi, I have attached a couple of photos regarding a Fuel Pressure Regulator I am looking for. Hoping someone may be able to help or even tell me if there is an equivalent part. Thanks Regards Andrew Membership No. 7050 1 Link to comment Share on other sites More sharing options...
Jessopia74 Posted June 9 Share Posted June 9 It’s a pulsation dampener, it does not regulate pressure. Cars run fine without, especially if using a more modern pump. They are still about as all the vehicles with K-Jetronic had them too. But they are as you have found not cheap. Link to comment Share on other sites More sharing options...
mantasrme Posted June 10 Share Posted June 10 As said you can remove it and run the car without any noticable difference. I don't think i've had one on any of my injected cars in the last 15 years or more. Not a single running issue or difference in drive or performance. Link to comment Share on other sites More sharing options...
Andrew Talbot-Scobie Posted June 10 Author Share Posted June 10 Thanks to mantasrme and Jessopia74 for your replies. As the car is running very rich, lots of white smoke etc. and revs are difficult to keep high enough to move. As my pressure regulator couldn't be adjusted, and the fact that when I switched my fuel pump off (have a separate switch) the engine revs would pick up, and run normal until of course it was starved of fuel. I was advised to get a replacement fuel regulator and go from there.. However as you say it can run well without one, I am at a bit of a loss at present. Unless you have any suggestions. Thanks again Regards Andrew (7050) 1 Link to comment Share on other sites More sharing options...
Ems Posted June 10 Share Posted June 10 The fuel pressure regulator is on the fuel rail which attaches to the inlet manifold. White smoke is usually from condensation in the exhaust or head gasket failure. 1 Link to comment Share on other sites More sharing options...
Jessopia74 Posted June 10 Share Posted June 10 As EMS said, white smoke is not over fueling, most likely head gasket. Fuel would be black smoke or poor starting with flooding at idle. FYI, your injection regulator sits between the injectors on your inlet manifold. I have added pic of its location looking at the manifold from above and what it will look like without pipes/once removed. Link to comment Share on other sites More sharing options...
Sutty2006 Posted June 12 Share Posted June 12 I’ve found one just incase you need it. 3 Link to comment Share on other sites More sharing options...
Andrew Talbot-Scobie Posted June 13 Author Share Posted June 13 Thanks for your reply your picture is a little different from the one I sent, not sure if it’s different because the engine came out of a 1986 Vauxhall Carlton 2.2i Anyway thanks for the info and what price would you sell the one you have. Thanks again Regards Andrew Link to comment Share on other sites More sharing options...
Sutty2006 Posted June 13 Share Posted June 13 5 hours ago, Andrew Talbot-Scobie said: Thanks for your reply your picture is a little different from the one I sent, not sure if it’s different because the engine came out of a 1986 Vauxhall Carlton 2.2i Anyway thanks for the info and what price would you sell the one you have. Thanks again Regards Andrew That first picture you sent is the vibration damper next to the fuel pump. Is that what you’re after? i have a 2.2i Carlton on my driveway if you need me to identify a component off it Link to comment Share on other sites More sharing options...
Andrew Talbot-Scobie Posted June 16 Author Share Posted June 16 Thanks for reply. Yes sorry to show my ignorance I was a little unsure what it was, or did. Mine is dented and has seen better days. I'm afraid as I am not up to speed on the injection system and the vibration damper. Can you tell me if I can run the car without one, and if the answer is no and I need one, can it be mounted away from the pump. Thanks again Regards Andrew Link to comment Share on other sites More sharing options...
Jessopia74 Posted June 16 Share Posted June 16 1 hour ago, Andrew Talbot-Scobie said: Thanks for reply. Yes sorry to show my ignorance I was a little unsure what it was, or did. Mine is dented and has seen better days. I'm afraid as I am not up to speed on the injection system and the vibration damper. Can you tell me if I can run the car without one, and if the answer is no and I need one, can it be mounted away from the pump. Thanks again Regards Andrew You do not need the pulsation dampener as stated in posts above. Link to comment Share on other sites More sharing options...
Andrew Talbot-Scobie Posted June 18 Author Share Posted June 18 On 16/06/2024 at 22:07, Jessopia74 said: You do not need the pulsation dampener as stated in posts above. Thanks for pointing that out again, hopefully when it's up and running I'ii get to say hello to you. Cheers 1 Link to comment Share on other sites More sharing options...
Jessopia74 Posted June 18 Share Posted June 18 57 minutes ago, Andrew Talbot-Scobie said: Thanks for pointing that out again, hopefully when it's up and running I'ii get to say hello to you. Cheers NP, it got a little confusing in the thread talking about Pulsation Damper and Fuel pressure regulators, so just wanted to make a clear statement about the Pulsation dampener Link to comment Share on other sites More sharing options...
1200bandit Posted June 18 Share Posted June 18 I think l have a you can adjust,some time since l seen it Link to comment Share on other sites More sharing options...
Andrew Talbot-Scobie Posted June 27 Author Share Posted June 27 👍 Link to comment Share on other sites More sharing options...
