My New A Series Project.
h0tr0dder_uk
Finally cut out my first chassis rail section...only 3 more to do
Here it is mocked up in place. As you can see it will make the whole front suspension unit sit approx 2-3" lower than standard.
Heres what the rear chassis rails mocked up so you can see how much narrower they will be
Finally got myself a welder (off ebay) but the bleeding thing doesn't arc properly so its going back.
In the meantime I did some more cutting - I cut out the other inner rear wheel arch.
This allowed me to copy the original chassis rail and work out how the new one will fit.
As you can see its will allow the axle to sit approx 3" lower than std. It will also be 2.5" box section (stronger than the 2" original)
Here you can see how the new rail will protrude into the interior slightly.
Edited by h0tr0dder_uk
Finally got my welder back so I tacked some 1 3/4" box section to both ends of the chassis rails
This helped to space the rails correctly and will slip inside the 2" box section that I'll use for the center chassis rails.
Then I temporarily clamped some more 1 3/4" box in the middle and tacked on the top and bottom.
and voila - the rail takes shape
All thats needed now is to finish weld it, grind it and do the other one.
Finished welding one of the chassis rails. Here you can see that it was welded in 1" increments to try and prevent warping. Check out how much splatter is produced from this flux cored wire (I went with this as apparently its better for thicker work, I'll stick to co2/argon mix for thinner stuff).
Heres a few pics of the rail before I linish down the welds
Now I need to grind them down and do the other side.
OK - finally got my chassis rails looking how I want them
But - I have stopped working on them now as I'm considering a new direction. I have found a GM car that uses a similar front suspension but has these major improvements :-
1) the track width is approx 3" narrower which would allow me to fit the wheels I want.
2) you can get dropped spindles
3) you can get big brakes kits
4) you can easily get 5 stud hubs
So - I'm gonna try and get my hand on one of these front suspension clips and build my chassis around that.
  • 5 months later...
OK - new update.
I havent done much on the car over the last few months as I've been enjoying my summer over here and trying to source a chevrolet chevette front suspension. After being messed around a lot I've decided to stick with the manta front suspension and modify it. I decided that the new chassis rails that I originally built wouldnt be strong enough for a V8 so I built the following rails
Also I decided to sell the F.A.S.T xfi fuel injection system that I was gonna use as I figured it would cost way to much to build a big horsepower small block chevy engine. Now I'm gonna buy a salvaged late model camaro and transplant the entire running gear (LS1 engine, 6 speed gearbox, axle etc) plus air con, radiator, steering column, etc etc
If anyone has a turbo front spoiler for one of these please let me know
Very nice project,I must say! Good luck with it! I was wandering if you could help me a bit...I saw your cardboard template of original chassis rails,and thats exactly what I need since my manta was crashed somewhere in the past,and those rails are slightly bent.Therefore,exact dimensions would mean a lot to me,and they are rotten too...so,if you can share,please do!! I`d appreciate your help!!
  • 4 weeks later...
"Very nice project,I must say! Good luck with it! I was wandering if you could help me a bit...I saw your cardboard template of original chassis rails,and thats exactly what I need since my manta was crashed somewhere in the past,and those rails are slightly bent.Therefore,exact dimensions would mean a lot to me,and they are rotten too...so,if you can share,please do!! I`d appreciate your help!!"
I'd love to help but unfortunately I wouldnt ba able to guarantee that my templates were 100% accurate. One of the reasons I cut off the original rails is that they had been cut off just in front of the front crossmember and another set welded on. Since I'm gonna be fitting a higher horsepower engine this wouldn't do.
  • 1 month later...
the only other pics I have are during the build
and when it was finished
My new project will be pretty much the same but with either
1) bigger deep dish wheels and a little lower
2)maybe just keep it on steels for a sleeper look
3) or stick to wide deep dish 15s
