MANTAMAN Posted August 24, 2013 Share Posted August 24, 2013 i spy with my little eye, a crusty chassie rail !!! now there's something unusual on a Manta.... NOT !!! Yes, the normal rust spots but your making fast work of tackling them, keep the sparks flying from your magic wand ( welder ! ) and the Manta will good and strong again, Billing next year ? Quote Link to comment Share on other sites More sharing options...
Novasportc550 Posted August 25, 2013 Author Share Posted August 25, 2013 i spy with my little eye, a crusty chassie rail !!! now there's something unusual on a Manta.... NOT !!! Yes, the normal rust spots but your making fast work of tackling them, keep the sparks flying from your magic wand ( welder ! ) and the Manta will good and strong again, Billing next year ? Yea needs both sides done, my plan is to weld both A pillars in, inner arches repaired, back arches cut out for the 400 kit, then put her on the roll over jig to do the chassic legs and clean the under sealer of ready for shot blasting.. Quote Link to comment Share on other sites More sharing options...
Novasportc550 Posted August 30, 2013 Author Share Posted August 30, 2013 Got these new lamps and h/lamp bezels today in the post thanks to paulmanta.. Cut the rear arch of and drivers sill. Offered up the rear 400 arch for trail fit and set on sill to check fitting. Bit of welding to do behind the sill at the rear before I can weld the sill on... 1 Quote Link to comment Share on other sites More sharing options...
steveopel Posted August 31, 2013 Share Posted August 31, 2013 (edited) Looking good and that kit looks really impressive how do the rear arches attach, im about to set to on the ones on mine. What happened to the hatchback is it in bits or did it get saved, it didnt look too bad from the photos and what are you doing with the original bezels are they for sale. Still would be nice to see another red 400R out there mind. Edited August 31, 2013 by steveopel Quote Link to comment Share on other sites More sharing options...
Novasportc550 Posted August 31, 2013 Author Share Posted August 31, 2013 Looking good and that kit looks really impressive how do the rear arches attach, im about to set to on the ones on mine. What happened to the hatchback is it in bits or did it get saved, it didnt look too bad from the photos and what are you doing with the original bezels are they for sale. Still would be nice to see another red 400R out there mind. Hi, the rear arches bolt on, I still have to drill the holes for it, but need to get the sill fitted to make sure it all lines up.. Doner car didn't make it, died 3 months ago. :-( Red would be nice, but have my heart set on white.. :-) Quote Link to comment Share on other sites More sharing options...
Novasportc550 Posted August 31, 2013 Author Share Posted August 31, 2013 Today's progress. Got the nasty rot cut out from the rear of the sill and started a bit of sealer removal from the rear arch, with is slow work. Also cleaned up the donor section for the rear sill and floor. Quote Link to comment Share on other sites More sharing options...
Novasportc550 Posted September 1, 2013 Author Share Posted September 1, 2013 (edited) All ready for the donor section.. :-) and second pic with it welded in Edited September 1, 2013 by Novasportc550 Quote Link to comment Share on other sites More sharing options...
Novasportc550 Posted September 8, 2013 Author Share Posted September 8, 2013 This weekends progress, drivers sill all welded on, drivers wing, side skirt and drivers rear arch all bolted on Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted September 8, 2013 Share Posted September 8, 2013 Looking good, are you making the rear arches removable? Quote Link to comment Share on other sites More sharing options...
Novasportc550 Posted September 9, 2013 Author Share Posted September 9, 2013 Looking good, are you making the rear arches removable? Yes sure am, think they look better that way Quote Link to comment Share on other sites More sharing options...
Novasportc550 Posted September 12, 2013 Author Share Posted September 12, 2013 Started to make the panel to fill in the gap from the body to the wheel arch tonight. This is my progress so far.. Quote Link to comment Share on other sites More sharing options...
Novasportc550 Posted September 18, 2013 Author Share Posted September 18, 2013 Small up date. Got the wheel arch welded in tonight... 2 Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted September 18, 2013 Share Posted September 18, 2013 looking good Quote Link to comment Share on other sites More sharing options...
Novasportc550 Posted September 19, 2013 Author Share Posted September 19, 2013 That's the main body work done on the drivers side, still the drivers chassis leg to do, but I will do that when she is on the roll over jig.. Now to start to the passenger side.. Quote Link to comment Share on other sites More sharing options...
Novasportc550 Posted September 20, 2013 Author Share Posted September 20, 2013 now has a big hole.. Quote Link to comment Share on other sites More sharing options...
Novasportc550 Posted September 20, 2013 Author Share Posted September 20, 2013 Got the floor pan welded in tonight.. 3 Quote Link to comment Share on other sites More sharing options...
Novasportc550 Posted September 22, 2013 Author Share Posted September 22, 2013 Bit more work done today, cut of the rotten pillar, trimmed up the second hand part and screwed it in place. Still to be welded in tho.. Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted September 22, 2013 Share Posted September 22, 2013 Now that pic with the 'a' post removed.. that's a brave move 1 Quote Link to comment Share on other sites More sharing options...
Novasportc550 Posted September 23, 2013 Author Share Posted September 23, 2013 Now that pic with the 'a' post removed.. that's a brave move Being a car body repairer for my trade helps.. Lol Quote Link to comment Share on other sites More sharing options...
Novasportc550 Posted September 27, 2013 Author Share Posted September 27, 2013 Passanger pillar now welled in.. Battery box is next on my list.. 1 Quote Link to comment Share on other sites More sharing options...
Novasportc550 Posted September 29, 2013 Author Share Posted September 29, 2013 Got lots done today, I am now totally wrecked tho.. Got the battery box welded in and the front wheel arch all welded up too.. 2 Quote Link to comment Share on other sites More sharing options...
Novasportc550 Posted October 1, 2013 Author Share Posted October 1, 2013 Postman brought me this today, a nice new passenger door skin... Quote Link to comment Share on other sites More sharing options...
StevieH Posted October 1, 2013 Share Posted October 1, 2013 you've got a nice postman then 1 Quote Link to comment Share on other sites More sharing options...
Clint Kember Posted October 1, 2013 Share Posted October 1, 2013 have you posted this on passion ford Quote Link to comment Share on other sites More sharing options...
Novasportc550 Posted October 1, 2013 Author Share Posted October 1, 2013 have you posted this on passion ford No chum, why you ask..!! Quote Link to comment Share on other sites More sharing options...
