Mig Welder?
Aggressor
I go 0.6mm for body
as for gas unless using a lot no cheaper for big bottle by the time you have bought regulators and rental, then there is the lugging it around. Pub size is not too bad. I have done a load over the last few years and pretty sure I'm on about even with no up front spend
I go 0.6mm for body
Thanks lads. and what slze wire would I need?
I'm with mantadoc, 0.6mm for body. But i do also have 0.8 for chassis work.
I use 0.6 for pretty much everything car based.
Try and get the best you can afford, one with a eurotorch setup is good, most cheap mugs suffer with poor wire feed causing crap welds. I converted my siegen 150 (sip) to eurotorch, it's an 'ok' welder for the amount of work I do.
I found a cebora ( snap on ) welder on ebay won it for £110 around 8 years ago never let me down welds anything :D .
best info I got told was buy the best you can afford at the time :) .
also buy a good mask auto darkening siegen ones are good.
What he said, mine is a Snap-mig 130, bought in 1987. 1 Min winding has become unreliable so I have to weld hot and fast.
This is the same thing more or less you see branded Cebora / taskmaster / BOC and a few others
