D16PJM Posted July 3, 2014 Share Posted July 3, 2014 well hopefully I haven't bitten of more than I can chew but here it is, needs lots of welding the boot area is the biggest worry. here it is once I got it home. here is the horror of the rest, I can see these are not made of the thickest metal hole near battery tray and inner wing. boot area I have taken the front wings off and it is better than I thought behind there, needs a couple of bits but have seen worse, the boot area is my concern as unsure what panels are available. Im beginning to think I may be mad. Pete 2 Quote Link to comment Share on other sites More sharing options...
andyp Posted July 3, 2014 Share Posted July 3, 2014 No.. you are not mad... you are just driven with passion.. Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted July 3, 2014 Share Posted July 3, 2014 ive seen tonnes worse, wont take much to get that sorted Quote Link to comment Share on other sites More sharing options...
MicsManta Posted July 3, 2014 Share Posted July 3, 2014 I agree with andy.and another reason is my manta is in far worse condition and i have had loads of people say why are you trying to repair your car its not worth it but i always say every good clasic car needs saving. so i think you should save yours. Quote Link to comment Share on other sites More sharing options...
D16PJM Posted July 3, 2014 Author Share Posted July 3, 2014 im all for saving cars, I bought this in pieces, cost £800, now owes me a small fortune, only a phone picture so not the best quality, if I can get the manta as good as this I will be over the moon Quote Link to comment Share on other sites More sharing options...
D16PJM Posted July 23, 2014 Author Share Posted July 23, 2014 Well with changing jobs recently iv had next to no time to do anything on the car, iv managed to remove the front wings, wire brush with a drill and treat the tin worm to stop it getting much worse, iv decided to start from the front back This is what I have so far. Drivers side passenger side Now I have to decide whether to plate it and have fun or do a proper job cutting out and replacing with new where available, the first option has an appeal as most will not be seen. 1 Quote Link to comment Share on other sites More sharing options...
Aggressor Posted July 25, 2014 Share Posted July 25, 2014 Get stuck in mate!! looks a great project Quote Link to comment Share on other sites More sharing options...
611 Posted July 25, 2014 Share Posted July 25, 2014 Thats just a light bit of welding for a manta, you should see some of the A series projects on here, some need the whole floor pan and boot floor replacing :-) If your going to keep it for a while do a proper cut and replace job if not then just plate it. If you just plate it and then end up keeping it you will have wished you had done a proper job, trust me been there done the job twice :-) nice looking car :-) Andy Quote Link to comment Share on other sites More sharing options...
D16PJM Posted August 28, 2014 Author Share Posted August 28, 2014 A small amount done tonight trying to get back into it, 1 hole on the inner wing cut out and a new piece put in, didn't get any pictures but has come out nice, also started on another hole, idea is to get the passenger side done first as that was the worst side, got my engine hoist at the ready to lift it out but finding somewhere to put it once out could be a problem as im out of room. Pete Quote Link to comment Share on other sites More sharing options...
Devil Fish Posted August 29, 2014 Share Posted August 29, 2014 Good luck with it dude.... will be fantastic when finished! Quote Link to comment Share on other sites More sharing options...
CRAZYDAVE Posted August 29, 2014 Share Posted August 29, 2014 Looks a better shell than most! Looking forward to updates Quote Link to comment Share on other sites More sharing options...
D16PJM Posted August 30, 2014 Author Share Posted August 30, 2014 another couple of hours done and the inner wing is looking a lot better, I have cut out where visible and let pieces in and cut and plated where not so visible as its a bit quicker. on the plated parts I normally use seam sealer so no water can get behind but got told the other day that it can actually cause it to rust, is that right. Pete 2 Quote Link to comment Share on other sites More sharing options...
opelmantagsi Posted August 30, 2014 Share Posted August 30, 2014 Will only rust if it's bare metal under the seam sealer. Joggle joints should be weld through primed, using weld through primer I epoxy prime everything before seam sealing. Many seam sealers out there, most are rubbish, I find the wurth product is the best, but 3m should be good Quote Link to comment Share on other sites More sharing options...
